ecu programing
hiscot
ecu programing
Post by hiscot » Fri Jun 02, 2006 6:09 pm
any one heard of Henry Roy from ardrossan or Ricky Gould huntly
regards bob
Post by jj » Fri Jun 02, 2006 6:28 pm
A mate has used Henry Roy to programme his emerald running his throttle bodied 106 recently and says the guys knowledge is awesome, apparently he is well known in Scotland for that sort of thing. Might not be very hand if your in Abz though.
hiscot
Post by hiscot » Fri Jun 02, 2006 6:47 pm
yer Ive heard hes brilliant any rough idear on cost
Post by jj » Fri Jun 02, 2006 6:48 pm
I`ll find out what his rates are and let you know.
Post by simon » Fri Jun 02, 2006 7:00 pm
Wait for one of the other Abz lot to post about Ricky, I'm sure quite a few of them have used him.
Post by Sanjøy » Fri Jun 02, 2006 7:14 pm
Pretty sure Ricky keeps Tuts car running.
Lawrence
Post by Lawrence » Fri Jun 02, 2006 10:26 pm
why not map it yourself?
Stu has a hire out kit...just add a laptop :)
hiscot
Post by hiscot » Sat Jun 03, 2006 7:50 am
Lawrence wrote:why not map it yourself?
I would love to but never done one before so dont know were to start its a dta s60 btw
Post by tut » Sat Jun 03, 2006 10:18 am
Bob
Ricky has been doing my car since 1999. He's a good friend now. He upgraded both my K engines and everything else that I have had done to the car. One of the old school, ie will repair or make a part himself as opposed to just fitting a new one.
He is well Elise experienced now, and the same with Emerald mapping, and has an oldish R/R. Labour rate is £28/hr.
Lawrence
Post by Lawrence » Sat Jun 03, 2006 10:31 am
Does your ECU log data?
http://www.dtafast.co.uk/news/latest_ne ... ete_Lambda
looks like it does :)
all you do is drive about logging the data for throttle, revs and lambda and then change the areas in the screenshot to the correct values
it's quite fun to do
hiscot
Post by hiscot » Sat Jun 03, 2006 11:16 am
Thanks Lawrence It also Logs upto 7 items in the data log but at the moment its running the wrong map big valves t boddies ect and is very rich, but I would like to learn what to do sounds easy but only if you know what figures to put where ??
I also want to go T boddies in the near future hence would be handy to learn then its just fit and retune wereas if its mapped now it would be a bit off a waste
Thanks Tut also heard good things about Ricky Gould but was told he sets up more for the track were as Henry Gould sets up more for drivabilty ie road and has loads of experance with the DTA S60 but £28 ph is very good plus he's closer
Lawrence
Post by Lawrence » Sat Jun 03, 2006 11:55 am
the wide band lambda screen gives you the afr figures
you simply swap them over to the fuel map with a bit of math
if you use the afr value of 14.7:1 for 1 lambda and each decimal is say 1% added or subtracted to the fuel numbers in the injection map
and before you ask why the computer doesn't do that, it probably will soon :)
we have the use of a couple of Emerald specific scripts that do a lot of the work for us
but when you map yourself then you soon see and hear the correct fueling and it gets easier :)
Post by tut » Sat Jun 03, 2006 3:48 pm
Bob
Do you have an Emerald or a DTA ecu?
hiscot
Post by hiscot » Sat Jun 03, 2006 3:53 pm
TUT
DTA S60 It will run your honda and comes with a 215 bhp honda base map
http://www.dtafast.co.uk/news/latest_ne ... Honda_K20A
It is also live mapping, auto fuel corrections ect ?????
I believe Ricky has done DTA but not S60 will have to phone I suspose
hiscot
Post by hiscot » Sat Jun 03, 2006 4:05 pm
Lawrence It got auto whatever you said, look at the link for Tut and look at V17.08 have to find out how to use and fit wide band maybe
