Warning..CRP makes you drive like a chav!
Big noise and I caught myself out this morning driving like a chav...seem to blip the throttle alot more when changing gear.
Reversing out the underground car park...
Select reverse
Blip throttle a few times as you slowly let out the clutch...same again when selectng 1st.
Does sound lovely though!!
Select reverse
- thinfourth
I fitted a Vaxhall Sports Exhaust (built by Janspeed I think) and a Viper this weekend... Also drilled out the precat in the downpipe (used for cold start emissions only and was a BITCH to remove)... First drive into work this morning was "interesting!"
I've went from completely standard washing machine sound to probably about the loudest possible combination on a VX
Think it might take a while to get over the self-conciousness, although I do find myself blipping the throttle and allowing it to over-run instead of shifting up... *Pop-pop-burble-burble*
Need to go for a good spirited blast tonight to see if I can actually feel the difference...
Lee
[flamesuit] VX220 owner[/flamesuit]
