Lotus website revised
GraemeLotus
Post by GraemeLotus » Wed Nov 02, 2016 4:09 pm
Hello all
Just a quick heads-up - the website's been revised again, to make it much easier to download brochures and view test drive reviews and social coverage.
The new used car locator content will increase over the coming weeks as we receive more dealer data
http://www.lotuscars.com
Cheers G
E92 325 C SE - Deutsch Verkehrsmitteln
mik
Re: Lotus website revised
Post by mik » Wed Nov 02, 2016 4:30 pm
Graeme - can you fix the specs for the Evora410? (edit: I originally said 400 - oops - now corrected)
Current power & torque figures cannot be correct - as discussed in this thread. Something is not right.....
2014 Evora S Sports Racer for him
2020 Audi E-Tron 55 Launch Edit for her
SAJ
Post by SAJ » Wed Nov 02, 2016 11:25 pm
Nice update to the site.
Noticed the Exige V6 Cup R and GT4 still on the site, can people still order these cars?
Instagram: @RevLimits
Stu160
Post by Stu160 » Thu Nov 03, 2016 12:02 am
Nice update, for some reason, I clicked on the the 311 first .....
Stu
S1 S160
Caterham 310R
GraemeLotus
Post by GraemeLotus » Thu Nov 03, 2016 11:23 am
The comments relate to 410 stats, not 400, correct?
mik
Post by mik » Thu Nov 03, 2016 2:23 pm
Hi Graeme,
Yes - only the 410 stats are wrong.
Hopefully this isn't an insulting level of explanation, but to explain what I mean.....
Power isn't measured - it's derived (from torque & rpm).
The calculation (for bhp and lbs/ft) is very simple :
Power = (Torque x rpm)/5252
If you plug 410bhp at 7000rpm into this equation, it is clear that you need to be making 307.62lbs.ft of torque at this point.
As the 410 spec sheet states max torque of 302lbs.ft at 3.5krpm (exactly the same as the Evora400), the maths doesn't work.
Either
a. The 410 isn't actually making 410bhp (which would not be good)
b. Your quoted max-torque figure should be higher (which would be good - unless you've promised your gearbox provided you won't go over 302 lbs.ft of course)
c. Your max torque figure is correct, but peak power is actually delivered at more than 7000rpm. Something like 7200rpm. (which would be good - unless you've promised your engine supplier a max rpm below this level.... and since my S1 Evora can rev to 7200rpm - I don't see that as likely).
I had already asked the question to @grouplotusplc on twitter, but no response.....
Post by Dominic » Thu Nov 03, 2016 2:58 pm
Never heard of this before, was under the impression things are a bit more complex than that. Every day's a school day.
Nice web site Graeme 8) :thumbsup
mik
Post by mik » Thu Nov 03, 2016 3:47 pm
Nah - it's simple. :)
But then you have to ask why the power figure is so important..... Which leads you into the complexity. :) but I don't want to hijack this thread..... So will shut up. :)
GraemeLotus
Post by GraemeLotus » Thu Nov 03, 2016 4:18 pm
.....and indeed you are correct with your proposed formula (interesting that it's two x pi, that's why divided by 5252...)
I will revert!
Post by tut » Thu Nov 03, 2016 4:43 pm
That is why if you look at a RR graph Dom, the power and torque curves should cross at 5252rpm.
mik
Post by mik » Sat Nov 05, 2016 11:36 am
Graeme - as highlighted by JayEm on TLF....
on the 410 page
1. The "aerodynamics" image is a 400, not a 410
2. The "Chassis" section is titled "chasis"
GraemeLotus
Post by GraemeLotus » Mon Nov 07, 2016 4:10 pm
mik wrote:Graeme - as highlighted by JayEm on TLF....
on the 410 page
yes spotted along with some others....colleagues have been made aware, thanks
