Rig scrappage on Isle of Lewis - clever lateral thinking?
Post by campbell » Thu Aug 25, 2016 2:38 pm
kerryxeg
Re: Rig scrappage on Isle of Lewis - clever lateral thinking
Post by kerryxeg » Thu Aug 25, 2016 4:20 pm
Hoho check the calendar. Remember the Brent Spar.
I guess if they couldn't make it seaworthy they'd consider options, but scrapping a rig is more complex than you think from an environmental perspective. There are certainly options within Europe, but Transocean have a scrapping program going on at the moment so this is part of a bigger scheme.
Co-incidentally I did a safety moment related to the incident - regarding the change of circumstance between a salvage tow and a normal rig move tow. We don't know the root cause of this incident but it will be interesting if this comes up in the investigation.
Post by Mikie711 » Thu Aug 25, 2016 11:34 pm
Breaking a tow bridle in heavy weather is not an unusual occurrence. It happens more often that you would imaging, especially in the North Sea.
The problem is that the bridle is secured to the pontoon via a Schmitt bracket and at least part of it spends the majority of it's life underwater only seeing the light if day for rig moves and sometimes not even then. This as you can imaging makes inspection difficult at best and usually only occurs at shipyard.
BMW M2 Comp
BMW R1300GS
kerryxeg
Post by kerryxeg » Fri Aug 26, 2016 8:34 am
The P&J actually had a letter just after the incident suggesting the rig should be left on the rocks as a tourist attraction.
Post by Mikie711 » Fri Aug 26, 2016 8:43 am
Someone has turned a rig into a restaurant somewhere, Amsterdam I think it is.
BMW M2 Comp
BMW R1300GS
Post by rossybee » Fri Aug 26, 2016 10:03 am
Mikie711 wrote:Someone has turned a rig into a restaurant somewhere, Amsterdam I think it is.
Sticky Toffee Pudding only on a Sunday :damnfunny
2004 Bentley Conti GT
Post by Corranga » Fri Aug 26, 2016 11:04 pm
Post by mwmackenzie » Sat Aug 27, 2016 5:55 pm
NOPE! It'll be closed on a Sunday up there Sir! :leave
