Extra long metal drill bit
jimbo
Post by jimbo » Sun Sep 20, 2015 1:50 pm
I'm trying to bore a hole through from my garage to the outside, above my up and over garage door for the purposes of running cable through it. I appear to have hit what I think is metal, both from the inside (after plasterboard and wood) and from the outside (after facing bricks). I can only presume that this is part of the framework for the garage door but I'm a good 6 inches higher so surprised by that. Either way, I don't have a drill bit for metal nearly long enough to go through it. Does anyone here by any chance? Circa 300mm x 12mm
S1 Elise 111s
Dave
Re: Extra long metal drill bit
Post by Dave » Sun Sep 20, 2015 2:58 pm
I presume your using a masonry drill, if you have the ability to sharpen it you should be able to drill through the metal frame, just don’t try and drill it at full speed.
thinfourth
Post by thinfourth » Sun Sep 20, 2015 3:57 pm
If no luck then i can TIG a drill onto a piece of hydraulic pipe
Post by Ferg » Sun Sep 20, 2015 6:16 pm
How about moving the hole a little left or right? Just enough to avoid the beam and mastic up the old hole.
Post by BiggestNizzy » Sun Sep 20, 2015 7:17 pm
Yes but its carbide and worth about £500.
jimbo
Post by jimbo » Sun Sep 20, 2015 7:37 pm
Can't move the hole as it's pretty much in the perfect spot, at least as far as neatness goes, but if it comes to it...
Sharpening is a decent shout, I'll give that a go first, but failing that the offer of welding onto a bit of thin pipe is spot on :thumbsup
Thanks guys
S1 Elise 111s
Post by Mikie711 » Sun Sep 20, 2015 11:13 pm
By the sound of things your trying to drill through the Catnic Lintel above your door. That will likely take some doing as there will be 2 layers of steel plate about 4mm each thick.
BMW M2 Comp
BMW R1300GS
Post by rossybee » Mon Sep 21, 2015 12:31 am
Mikie711 wrote:By the sound of things your trying to drill through the Catnic Lintel above your door. That will likely take some doing as there will be 2 layers of steel plate about 4mm each thick.
Move holes :blackeye
2004 Bentley Conti GT
Post by tut » Mon Sep 21, 2015 8:33 am
Best advice yet Ross, that is what I did in the bathroom, but the missus was not convinced.
Post by Dominic » Mon Sep 21, 2015 12:35 pm
tut wrote:Best advice yet Ross, that is what I did in the bathroom, but the missus was not convinced.
:shock: :damnfunny
jimbo
Post by jimbo » Tue Sep 22, 2015 8:04 am
Sorry for the late reply was away the last couple of days. Interesting, that's what a friend suggested it might be. Thanks for the advice, I'll look into options for moving it, just have to try and hide the cable runs I guess.
S1 Elise 111s
thinfourth
Post by thinfourth » Tue Sep 22, 2015 6:08 pm
Looking online a catnip lintel is steel | insulation | steel
It should be a piece of piss to get through
Bring me 1 x12mm drill of decent quality and I shall weld it to a lump of bar or pipe
Or if you want to go bigger i have an old mill welded to a piece of pipe already, but being a flat grind it might go anywhere and it is roughly 16mm OD
Post by Mikie711 » Tue Sep 22, 2015 7:53 pm
If it's in his garage it won't have the insulation infill. It will probably be the one that looks like an upside down T.
BMW M2 Comp
BMW R1300GS
Callummarshall
Post by Callummarshall » Wed Sep 23, 2015 10:57 pm
I think I have something which may fit the bill at work which could be procured if needs be, what sort of shank does your drill take?
Also, we have a drill sharpener/decent grinding wheel so could possibly re grind your existing drill.
jimbo
Post by jimbo » Fri Sep 25, 2015 9:36 am
I have a straight shank drill and an sds one too mate
S1 Elise 111s
