Headlight Lacquer repair
- thesurfbus
The lacquer has started to flake off my headlights, is there anywhere recommended to refurbish them in the Edinburgh area?
Alternatively has anyone gone down the DIY route?
Lotus Elise 220 S
Re: Headlight Lacquer repair
Have you looked at the LED replacements?
- thesurfbus
No I haven't heard of them, probably out my budget though.
Lotus Elise 220 S
Have a look at this post on SELOC
https://forums.seloc.org/viewthread.php?tid=462455
Alan
S2 111S
S2 111S
Is yours an S1 or S2
- thesurfbus
- thesurfbus
Lotus Elise 220 S
I thought you had an S1 per your avatar, hence the LED suggestion.
- thesurfbus
I know I need to change itI thought you had an S1 per your avatar, hence the LED suggestion.
Lotus Elise 220 S
Did you find anyone that carries out this refurb? Needing this done on mine.thesurfbus wrote: ↑Thu Aug 22, 2019 11:15 amThe lacquer has started to flake off my headlights, is there anywhere recommended to refurbish them in the Edinburgh area?
I think Craig of CMC has sorted this out for some Evora owners. Similar prob on those.
Give him a call to see.
- thesurfbus
Craig uses Protek for his headlight refurbs, unfortuneately out of my budget, so will be going down the DIY route over the winter.
Lotus Elise 220 S
Generally if I have anything plastic that is scratched or degraded I use TCut or rubbing compound to polish it up and have to date never had a bad outcome.
