S1 Elise Motorsport replica project
stratosboy
Post by stratosboy » Mon Dec 18, 2017 3:46 pm
Hi - I'm new on here and thought I'd post some pics of my project:
started with buying this in the summer:
lovely 99 Elise S1, high mileage and in need of a refurb, but lovely to drive.
I'd previously bought these:
which needed a lot of fettling to get a good enough finish. These are widened arched clams, about 50 mm each side at the rear and 20mm each side at front. I intend to fit 17x9 and 18x10" wheels.
Elise stripped out and parts I didn't need sold off.
Roll cage arrived:Image and fitted, tricky under dash, but went in and fits really well...ImageImageImage
I'll post some more of the build later in week
C7Steve
Re: S1 Elise Motorsport replica project
Post by C7Steve » Mon Dec 18, 2017 5:10 pm
Steve.
stratosboy
Post by stratosboy » Mon Dec 18, 2017 5:17 pm
a bit more..
I've had the suspension completely refreshed and modified, using S2 uprights and hubs. All parts have been chemically cleaned and re-coated in yellow zinc passivate and then 2 coats of clear POR 15 to keep corrosion at bay.
I've fitted Nitron spherical wishbone bearings and new NTR 40 struts, A quick rack and new Elise Parts steering arms.
Rear brace bar to try to keep rear subframe from twisting. (VAG 1.8t 20v engine being tuned for 500bhp)
Brakes are: Front - new AP Caparo 4 pot calipers with 308mm AP discs and floating bells
Rears - new AP 2 pot calipers (from the front) again with 308mm AP discs and floating bells - High Spec Spot calipers for handbrake duties
Pagid RS 14 pads
stratosboy
Post by stratosboy » Mon Dec 18, 2017 5:36 pm
these are to go in when I've sorted the OEM seat belts and Harness fittings:
also some extra gauges to know what's happening engine wise:
(who needs a heater and radio anyway?)
stratosboy
Post by stratosboy » Mon Dec 18, 2017 7:04 pm
engine and transmission:
Engine is away at builders at present, aiming for 500bhp, with re-bore, gas flowed AGU large port head, forged internals and new TFSi crank - effectively a stroker engine. with large turbo. This will be charged cooled:Image
Modified inlet manifold:
and baffled sump:
transmission: VAG 02M 6 speed gearbox: (planning for Quaife LSD to be fitted next year)
and bespoke drive-shafts made specifically for the car and power output, these have GKN cv joints each end
Post by Ferg » Mon Dec 18, 2017 8:09 pm
😲 Going for it! Looks great. 😎
Post by campbell » Mon Dec 18, 2017 8:51 pm
Awesome build thread. Money no object?! Suspect you have a bit of engineering talent there
Keep it coming.
stratosboy
Post by stratosboy » Mon Dec 18, 2017 9:10 pm
Not being modest, but no real engineering talent of mine, just interest and self-learning over the years. (I'm a recently retired NHS psychotherapist).
wouldn't say 'money no object' either, sold this:Image - Spyder zetec dhc S4 Elan to pay for this project and want to do it right. But thank you.
Post by Dominic » Mon Dec 18, 2017 9:20 pm
Great stuff! Looking forward to seeing further progress.
Love the Elan too.
Post by campbell » Mon Dec 18, 2017 9:23 pm
Smiling here. The money no object ref was a bit trigger happy, the sentiment was that you are "doing it right". Lots of attention to detail etc. Good on you.
Wish I had the time and talent to take on such a project. I too have a 99 Elise with very high miles. Had planned a major refurb when budget allowed but things have changed a bit.
Looking forward to your progress.
van cleef
Post by van cleef » Mon Dec 18, 2017 10:19 pm
Dear god I do like these kind of build thread....I thought I'd spent a small fortune on my S2 this year but it seems to be dwarfed by this.
How does the VAG lump compare in weigh to the original engine?
stratosboy
Post by stratosboy » Mon Dec 18, 2017 11:00 pm
it is definitely heavier, by about 50kgs I think. but the extra power and torque will more than make up for the added lard.
Another builder near me has an S2 Exige with a VAG 2.0 TFSI engine and this comes out at exactly the same weight as the stock S2 Exige (not sure if the Toyota engine and box is particularly heavy)
Stu160
Post by Stu160 » Mon Dec 18, 2017 11:25 pm
Looks great.
Stu
S1 S160
Caterham 310R
stratosboy
Post by stratosboy » Sat Dec 23, 2017 3:51 pm
my Christmas holiday job....fitting the Laminova
philthy
Post by philthy » Sat Dec 23, 2017 5:43 pm
Subscribing, loving your work so far
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
