S2 Exige S
Neil A
S2 Exige S
Post by Neil A » Fri Feb 17, 2017 12:14 am
This may be a little jumbled up as copy and paste from another site I use
Last week I said bye bye to the beetle :(
With offshore work being so unpredictable at the moment I decided to be sensible and free up some cash so sold what will probably be the fastest and best car I will ever own :sad::cry:
Did take something fun in px though :banana::banana:
2006 exige s withe supercharge Toyota engine
Power
288bhp - RSTuning
Pro alloy charge cooler
Pro alloy triple pass rad
TRD air intake
550cc injectors
260 cup fuel pump
2.9" charger pulley
2ubular manifold
2ubular 3" exhaust
Gearbox
Exedy clutch
LSD
Rebuilt box
Jubu 3rd 4th gears
Bodywork
Carbon front splitter
Alloy rear diffuser
Carbon rear wing
260 cup roof
Carbon GT3 clams -5" wider than a exige
Led lights
Lotus green respray
Interior
Alcantara momo wheel
Probax seats
alcantara door inserts
Carbon dipped side/dash panels - will be getting flocked
Chassis
Nitron shocks
powdercoated , rebuilt wishbones
AP292 front discs
Pagid RS14 pads
Braided lines
pro race 1.2 wheels
16 x 7 front 195 AO48 tyres
17 x 9 rear 255 AO48 tyres[
Neil A
Re: S2 Exige S
Post by Neil A » Fri Feb 17, 2017 12:17 am
Few parts started to arrive for the car , and had a bit of time now I'm home from work to start going through the car .
Looks to have a lot of nice parts but also a few bodges so will take a little bit more work than I thought.
I have got some oil temp and pressure gauges , may use the temp one for the gearbox to start with to get an idea of how hot the box actually gets.
Unfortunately due to a mix up at the dvla the V5 got lost , so have now had to re apply, this has also meant i can't road tax the car :cry:
Did get my road wheels mounted up and adjusted the ride height up as it was set at 105 front /115 rear when loaded with 75kg in each seat.
Neil A
Re: S2 Exige S
Post by Neil A » Fri Feb 17, 2017 12:19 am
So today the car came to bits, and is now in the rebuild stage complete with now having a boot/storage space .
Looks good with the roof off.
Rear spoiler,roof and rear clam removed
Rear storage box is now ready to fit, front is covered in a double layer of heat barrier with around 2" of clearance from the manifold. Still have access to the battery and have air flow either side to allow heat to escape through the rear vents.
Neil A
Re: S2 Exige S
Post by Neil A » Fri Feb 17, 2017 12:20 am
Oil cooler is now fitted in the nearside rear , I will monitor temps and if needed vent the arch liner to increase flow.
Gauges now fitted and wired
Ive also added extra bracing to the front splitter as it was flexing above 80mph and actually hitting the road, I also had to modify a front tow post to work with the gt3 clam.
Ive still to make two little trim pieces for the side of the boot box, but atlas now have somewhere to put stuff if going for a run or to a track day.
Also tracked down an under tray so will get that fitted at the end of the week , also got a digital temp gauge to fit to the gearbox to see how hot its getting before I decide if I'm going to fit a cooler and pump.
Another big thanks to wheelcoat for the 2 day turn around on my wheels even though I said no rush lol
pete
Vexatious Litigant
Re: S2 Exige S
Post by pete » Fri Feb 17, 2017 12:23 am
Nice
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
C7Steve
Re: S2 Exige S
Post by C7Steve » Fri Feb 17, 2017 12:31 am
Steve.
Neil A
Re: S2 Exige S
Post by Neil A » Fri Feb 17, 2017 12:50 am
sadly since I've bought the car the weather has been poor So not had much use out of it, in a way it's a good things meant I got on and did most of the jobs I had planned to do over the next 6 months.
I still plan long term to get wider rear wishbones made for the rear to let me run without rear spacers but for now I'm going to enjoy the car as much as possible. I will say it is very loud and wouldn't like to go for a long trip,in it but that wasn't what I bought the car for.
Re: S2 Exige S
Post by mwmackenzie » Fri Feb 17, 2017 1:15 am
That's freaking gorgeous! :thumbsup
:love
Re: S2 Exige S
Post by Scotty C » Fri Feb 17, 2017 9:06 am
i like that apart from the Massove spoiler and splitter.
a4drk
Re: S2 Exige S
Post by a4drk » Sat Feb 18, 2017 7:46 pm
Agree with Scotty. Front splitter is ok, but the rear spoiler is far too big.
Wonder if the 2010 spoiler would fit in the same holes .......
S2 Exige
Neil A
Re: S2 Exige S
Post by Neil A » Sat Feb 18, 2017 10:31 pm
The pictures make it look even bigger than it is , it is huge but think its fitting with the rest of the car and is the same as the GT3 race cars were fitted with
Kinger
Re: S2 Exige S
Post by Kinger » Sun Feb 19, 2017 12:30 am
Looks great, looking forward to seeing it at KH on the 25th March
SAJ
Re: S2 Exige S
Post by SAJ » Sun Feb 19, 2017 7:03 am
Neil A wrote:The pictures make it look even bigger than it is , it is huge but think its fitting with the rest of the car and is the same as the GT3 race cars were fitted with
Looks good to me :thumbsup
Instagram: @RevLimits
Neil A
Re: S2 Exige S
Post by Neil A » Tue Mar 28, 2017 11:34 am
Did my first tacky yesterday in this car :) , thanks to John for sorting the day and for the photos. Sorry for my driving on the day going to take a while to build confidence to push the car harder Im use to fwd.
Sadly never got around to putting my go pro in the car .
Was good fun but the car definitely needs the roll bars as the springs are a bit soft causing roll in the corners.
Rolly
Hard on the brakes at end of the straight chasing the GT3, this will explain the worn splitter :lol:
Re: S2 Exige S
Post by Scotty C » Tue Mar 28, 2017 4:12 pm
that front splitter will be costing you 5-10 mph on the straight.
