S1 Elise Motorsport replica project
stratosboy
Re: S1 Elise Motorsport replica project
Post by stratosboy » Sun Aug 04, 2019 9:05 pm
the tripoddy thing pictured above, designed to stop the turbo from flexing/moving as there's a lot of weight in it
stratosboy
Post by stratosboy » Thu Oct 17, 2019 9:09 pm
not much progress over last couple of months, but now finished fitting lights, grills etc to clams:
front:
rear:
stratosboy
Post by stratosboy » Sun Oct 20, 2019 6:24 pm
front fitted yesterday for final time, all wired up
Post by campbell » Sun Oct 20, 2019 6:33 pm
Phwoar.
We really are getting there, eh
Post by j2 lot » Sun Oct 20, 2019 7:51 pm
8) :thumbsup
That looks stunning - great job.
stratosboy
Post by stratosboy » Tue Apr 21, 2020 9:54 pm
some progress since last update: handbrake cable fitted (works well) - new clutch master cylinder fitted (waiting for ECS bleeder block for slave cyliner end) - gear linkage/cables (S2 Toyota) all connected up - cooling system all connected - Stack gauges and GAWR dash fitted (not wired in yet) - seats trial fitted.
Sorting out fuel lines just now. Electrics/wiring final job - will post some pics soon.
Stu160
Post by Stu160 » Tue Apr 21, 2020 10:21 pm
Looks epic.
S1 S160
Caterham 310R
stratosboy
Post by stratosboy » Thu May 07, 2020 7:21 pm
some further developments:
Had a helpful visit from the owner of a Miami Blue S2 Audi Exige (400+bhp): think there's another Miami Blue S2 down south
I've ordered one of these to connect the Lotus braided clutch line to the VAG slave cylinder:
I'm busy with final oil and breather plumbing in, using PTFE Nylon braided lines and black AN fittings from Torques - good stuff
Post by Scotty C » Mon May 11, 2020 11:10 am
nice looking build
stratosboy
Post by stratosboy » Fri Jun 05, 2020 3:27 pm
thank you, got my intake fabricated this week, and will post it mounted when it arrives
Post by robin » Sat Jun 06, 2020 9:42 am
Looks great, love the colour!
I know the old S2 240 intercooler added a bit of throttle lag and you've got 2x the charge running through a similar sized intercooler, so I think that means 2x the pressure (not sure of the fisics there). Does it have a blow off valve type of thing? I guess it must, all proper turbo engines do :-)
Anyway, it's going to be awesome - hope to see it at a trackday somewhere once it's running - Oulton Park would be ideal!
stratosboy
Post by stratosboy » Sat Jun 06, 2020 8:38 pm
Thanks Robin,
yes I have an external wastegate to manage excess pressure at the turbo, and then there is a blow off valve plumbed into the top of the chargecooler, before the airflow moves into the plenum chamber, you may see it below, opposite the plenum. I'm hoping this will be enough to manage the pressure.
Post by robin » Wed Jun 10, 2020 8:09 am
For the S/C that challenge was that the bypass valve at the compressor stops it generating more boost, but the "boost" that's compressed in the intercooler is still in the system and coupled with the electronic throttle you always got a split second more "drive" out of the engine when you were jumping from full throttle, high revs to throttle shut, on the brakes. If your blow off valve is PWM operated by the ECU then I guess the ECU can open the blow off valve as the throttle shuts. Tricky to get it right (you don't want to lose the boost if you're just feathering the throttle mid corner).
There are some drag racers in the US that run American V8s (I don't know all about the different V8 engines, these are from Corvettes I think). One of their cars has twin big turbos, straight exhaust (no silencers), running 30psi of boost some days. They have problems bleeding the boost off - they need massive dump valves, with pipes bigger than some cars exhaust pipes. Proper job! Anyway, they spend quite a lot of time tuning the boost map to keep the car connected to the track - you may have the same challenges ;-)
stratosboy
Post by stratosboy » Wed Jun 10, 2020 9:14 pm
cheers Robin,
appreciate your thoughts on this, I'll check out what your saying here, with my engine builder. Should be ok, as this is a tried and tested conversion, with plenty of Audi turbo engined Elise's out there now.
Post by Mikie711 » Thu Jun 11, 2020 12:01 am
The quality of your build is clear for all to see. Be one hell of a car when you get it finished. Be interesting to see if reality meets your expectations.
BMW M2 Comp
BMW R1300GS
