Thanks Dezzy, mine is shotblasted and as the clam has to come off to fit a new windscreen, I can fit it at the same time.
Black and Silver Lotus badges
Ok Tut. Send me your address and I'll post it to you.
BTW, as it's an S2 badge, it wasn't screwed in from the back. It still has the wee pins, but it was just stuck on. Same with the new one. Supposedly most S1 owners don't bother replacing the bolts from the back when they replace it and just stick it on instead.
D
D
Tut, when I fitted mine, I marked the position of the studs on the old badge using the new one as a template, buffed the enamel off the old badge with a dremel and then drill out the studs from above. A ten minute job and the new badge was just bonded on.tut wrote:Thanks Dezzy, mine is shotblasted and as the clam has to come off to fit a new windscreen, I can fit it at the same time.
