Hiya. Hope you don't mind a VX220 owner cross posting an advert from the VX site, but it's a Lotus Elise part so thought there might be some local interest on here.
I'm fitting a full SD roll cage to my VX220 at the moment, so the harness bar Lotus fitted to my car back in 2003 is surplus to requirements. It is a S2 Sport 190 harness bar.
It's a bit of a faff to get it fitted in a VX, as it does not have the proper mounting on the roll hoop. But it should be a straightforward fit for S2 Elises and Exiges as it is designed to fit the rear bulkhead/speaker panel set-up on the Elise (I'd recommend confirming this with Lotus though).
Advert and some photos on VX site http://www.vx220.org.uk/forums/index.ph ... opic=49346
Genuine Lotus Harness Bar
Red VX220 Turbo - slightly modified
