No problem - look for meGourlay83 wrote:A couple of friends are coming down, just to watch. Any chance some of you could take them out, make it a better day for them.
Thanks
Alan
Bookatrack at Knockhill
Re: Bookatrack at Knockhill
Now with half an engine
+1tonyg wrote:No problem - look for meGourlay83 wrote:A couple of friends are coming down, just to watch. Any chance some of you could take them out, make it a better day for them.
Thanks
Alan
Aging biker
Obviously..........
Thanks Tut,
Won't be able to get the time off to attend which is a shame as I've not been on track all year and I was one of only three SE'rs to do the original BAT full track day.
Are we meeting up at the usual place for the drive down or is everybody making their own way there?
TBA
TBA
Don't know if I will make it now Mike.
My left back wheel has a wobble on it that everybody behind me saw, will jack up and check today, doubt if it will be a wheel bearing as it has held out for so many miles. Not so noticeable from inside on the straight, feels like a wheel out of balance, but does not like tight corners.
Shell Petrol Station after Bridge of Dee. 6.00 amMikie711 wrote:Are we meeting up at the usual place for the drive down or is everybody making their own way there?
Alan
I'm trailering so will trundle down early, will be too slow to run in convoy. You'll probably pass me on A90, plan to fuel up either at the Shell just past Bridge of Dee or in Dundee. Although a nice day forecast, trailer gives option of carrying loads of fuel, also have barely legal tyres on 2-11.
Regarding tyre's, I have been a bit remiss and did not order up a new set early enough and might struggle to make this set last a full day. Oulton the other week was a bit harder on them than anticipated. Jonny is bringing a set of rears for me but he has no fronts. There is a set of fronts at Murray's though.
Is anyone coming up from Edinburgh who could possibly collect the pair of fronts for me this afternoon in Sighthill? Failing that, can always nip down myself at lunchtime to collect with RR, should not take too long.
Aging biker
Just jacked the car up and put it on axle stands so that I could spin the rear wheels. No sign of anything mechanical, wheel bearing quiet, no vertical or horizontal movement, rear toelink tight etc. Took the wheel off to check that it had been put on square, and there was ali shavings on the wheel face that I cleaned off. However then noticed that the brake pad pin was hanging off, the spring collette had snapped so the pads were floating free. Fitted a new pin and checked for run out again, and though there was a little, twas a lot less than original.
The pin would not have caused that on its own, but something worked so happy now that I know it is not a mechanical failure, and KH is definitely on.
Two places left and a lovely sunny day forecast.
Any more S_E'rs joining us to take the Southeners on?
Sounds OK to me (I'll probably be late - no surprise to anyone who knows me)Gourlay83 wrote:Shell Petrol Station after Bridge of Dee. 6.00 amMikie711 wrote:Are we meeting up at the usual place for the drive down or is everybody making their own way there????
Alan
That'll be the wobble I spotted after the AMP3 day? Looked like a badly out of balance tyre, or buckled wheel!tut wrote:Don't know if I will make it now Mike.
Jamie McDonald
http://www.McDonald-Minis.co.uk
What a day,
C.V boot split (Outer) so had to get poor cheese to replace it for me, thanks feck for mates.
If it wasn't for Mike and Cheese i wouldn't have managed tomorrow, thanks guys
Alan
Alan
you lucky bandits!
Hope it was a good day - would have much rather been at Kh than the office
- Modena Scotland
Went up to KH for 2 hours. There were many SEers there to banter.
Thanks to Mike, Tut and Alan for the pax laps.
Alan, your arm wasn't causing you much problems in term of track driving. Hope you got used to the new lines and improved the lap time by at least 1.5 seconds by 5pm.
A Senna
Shared SE Calendar
