VVC Manifold
Wacky Racer
VVC Manifold
Is there any performance benifit in fitting a VVC alloy inlet manifold and injectors to a standard S2 rover engine?
" I'm suffering the heatbreak of sobriety"
I would say the gains are masked by the losses. Mid range just disappears. In hindsight I wish I hadn't fitted one, I had to fit a 4-2-1 to regain torque at sensible revs but I port matched it to the head so I couldn't go back.
Depends on the state of the head, I'd say. On a standard engine it'll do feck all, but I'll bet it helps a ported head gain a few hp further up the rev range.Brunty wrote:Has anyone got RR graphs to show before/after?
I'd suspect that a lot of the loss/gain may be psychological.
Yeah, you omit to mention it was fitted with 270 cams and a head port at the same time dude - I'll bet that killed more torque than the VVC plenumRICHARDHUMBLE wrote:I would say the gains are masked by the losses. Mid range just disappears. In hindsight I wish I hadn't fitted one, I had to fit a 4-2-1 to regain torque at sensible revs but I port matched it to the head so I couldn't go back.
I'm not sure how else you would account for the 135's early dip in torque (it uses the same cams).
The type of porting they do the head itself is unlikely to be harmful to torque. Sure, there is more that can be done, even while keeping the standard valves, but there is nothing "bad" in there, when compared to say the head that got fitted to Campbell's car or the RLC.
If properly port matched, I suspect that the torque loss due to lower air speed in the manifold will be negligible.
But, there are plenty of engines out there making 160 on plastic plenums so I am not sure what the calling for the (heavier) alloy inlet plenum really is, other than to make the engines look different!
True enough. RR would be good to see.Shug wrote:Yeah, you omit to mention it was fitted with 270 cams and a head port at the same time dude - I'll bet that killed more torque than the VVC plenumRICHARDHUMBLE wrote:I would say the gains are masked by the losses. Mid range just disappears. In hindsight I wish I hadn't fitted one, I had to fit a 4-2-1 to regain torque at sensible revs but I port matched it to the head so I couldn't go back.
