RATTLING
RATTLING
Hi all,
I picked up my S2 on Saturday and had a wonderful time, driving back up from Birmingham to Peebles. I have just noticed that there seems to be a rattling noise coming from the rear. Sounds like a loose metal plate or something similar. Does anyone have any ideas what this could be?
My technical knowledge is as good as a baby!
Undertray is probaly loose, go round all the bolts with an 8mm socket and tweak them all tight.
Also empty all the loose change fomr under the seat. You'll find about £20 in pennies...
On most S2 undertrays the bolts around the rim are M5 with 8mm heads and the four center bolts are M8 with 13mm heads, though some are domed/cap heads instead.
However, on the S2 there is a support plate that lives in the lower rear wheel arches -approximately triangular and more-or-less vertical. That is often loose - you would need to remove the undertray to see it and re-fasten it.
- Victor Meldrew
Yeah Ross, was about to say, get up and see Ali at SLS, you will find a post in here regarding him establishing himself having broken away from Murray's.
Sounds like your car could do with a once over matey, then you can start adding extras...
Will give you a ring tonight and you can tell me all about it!
Dave
Dave
