Derek
by Derek » Sat Jan 14, 2006 3:08 pm
Gareth,
What pressures are you running the 48's at? Finally geting around to fitting them.
by Gareth » Sat Jan 14, 2006 3:46 pm
If I remember rightly, 20psi front 22 rear...I think.
It was low anyway
Derek
by Derek » Sat Jan 14, 2006 4:09 pm
Cheers!
by mac » Sat Jan 14, 2006 5:20 pm
Fecking hell Gareth
That's way below the factory recomended settings (for factory read Lotus Motorsport)
28psi Cold resetting to 30psi hot if required
Derek
by Derek » Sat Jan 14, 2006 5:32 pm
Better get out to the compressor again!
The wheels were originally destined for Japan, and have a yellow band around them. In reality, this doesn't look as good against the krypton paint as I'd hoped.
Style over subtance I know, but they may be up for sale soon
by Gareth » Sat Jan 14, 2006 5:40 pm
mac wrote:Fecking hell Gareth
Yup, it's below Lotus recomendations. Maybe put it up to 22/24. Definately not as high as 28. This will wear the middle of the tyre due to ballooning. I should add, my settings are for the wet and cold weather.
by mac » Sat Jan 14, 2006 6:13 pm
I've ran mine at the lotus specified PSI and had no issues with uneven wear.
TBH that was with bog standard geo and ride height. I've manage to get the best part of a whole years track usage out of them, and they do work well on track at that poundage.
Pays your money, takes your choice, I suppose.
by alicrozier » Sat Jan 14, 2006 6:36 pm
I've dropped mine to 20/22 (cold)...
I ran factory settings for a while but I was getting more wear in the centres (hence too high).
Ali
by Gareth » Sat Jan 14, 2006 6:49 pm
I'm sticking with 20/22.
- Site Admin
by simon » Sat Jan 14, 2006 7:37 pm
Where'd you get the wheels from Derek?
Derek
by Derek » Sat Jan 14, 2006 8:08 pm
I got then at the Stoneleigh show in November, from SW Lotus Centre (much cheapness). Only got the longer bolts from MMC the other day though, and today was the first time on the car. I just don't think they look right on it though.
gordon
by gordon » Sat Jan 14, 2006 10:19 pm
Any pics to show the boys? They cant look that bad surely?
by Stephen » Sat Jan 14, 2006 11:43 pm
If they look bad go faster
Derek
by Derek » Sun Jan 15, 2006 2:43 pm
What do you think then?
Actually they are growing on me.
by mckeann » Sun Jan 15, 2006 2:48 pm
yuck
Is it not just a sticker?? pull it off
