The other day I arrived home to find that the inner arch had fallen onto the tyre and had been rubbing. This was AFTER the tyres had been replaced 2 days before. So I was annoyed that the tyre was slightly damaged.
The inner arch is worn away in several places. I screwed it back on with some new fixing points but it will need a whole new arch.
Is this a common problem on Elises?
It looks like I need to remove a fair bit of stuff from inside the inspection cover by the washer bottle.
Anyone know how much one costs? I'll call MMC but I suspect its not cheap.
Why couldt this happen before the new tyres were fitted and why is it connected using useless plastic screws?
