Welding - FALC
Welding - FALC
Post by Rich H » Mon Jun 25, 2007 10:06 am
Morning all,
I'm thinking about learning to weld but I don't know where to start.
Which is the easest to learn: MIG, Arc or gas?
Ideally I'd love to learn to TIG but that is some way off.... :)
Tom
Post by Tom » Mon Jun 25, 2007 10:46 am
I just completed a welding course. It covered intro to acetyline(sp?) and intro to MIG. also did a bit of MMA (stick), and was shown TIG but didn't actually try it myself.
stick welding is pretty easy
oxy i liked because you can take your time and make a decent job, even if you're not particularly skilled
MIG is ideal as the gun feeds the wire and once it's set up right is really fast. problem though if you're learning is getting used to the speed.
TIG i would leave until you've mastered the others (ie MIG) as the consumables are v expensive and it's easy to cock up a rod.
basically, IMO, start with oxy and MIG and get the hang of them, and maybe fit in a bit of arc/stick/MMA. then think about TIG..
HTH :thumbsup
1995 Volvo 940SE Estate
Tom
Post by Tom » Mon Jun 25, 2007 10:47 am
ans to your question, start with gas... :D
Post by Rich H » Mon Jun 25, 2007 11:06 am
Cheers Tom.
All look for a little oxy set then.
Ta
/soon to be charred faction...
Post by BiggestNizzy » Mon Jun 25, 2007 11:54 am
MIG is relativly easy to pick up. TIG takes a bit of practice but you can do some lovely herringbone welds, If memory serves me right though equipment is pricey. Gas is better if your working on rusty cars.
Post by Rich H » Mon Jun 25, 2007 12:46 pm
Gas it also useful for heating things up too. And ligting BBQs :thumbsup
I'll get shopping....
Post by BiggestNizzy » Mon Jun 25, 2007 1:38 pm
You may find an Oxy- Acyteline BBQ leaves things burnt on the inside raw on the outside.
As we have just had the HSE in today.
http://www.hse.gov.uk/pubns/indg327.pdf
usefull if your finding it hard to sleep.
A jet engine sausage toaster sounds more fun and it runs LPG all you need is a turbo and some tube.
bertieduff
Post by bertieduff » Mon Jun 25, 2007 2:23 pm
:shock: Scarey stuff. My other half does a similar thing about once a month, although hosing her down I've yet to try.... :idea:
MacK
Re: Welding - FALC
Post by MacK » Mon Jun 25, 2007 4:59 pm
Spot Welding, just press the button/lever/pedal at the right time :thumbsup
HTH
:wink:
Post by Rich H » Mon Jun 25, 2007 5:35 pm
:roll: :P
