Stereo Issues...
Ron
Stereo Issues...
Post by Ron » Mon Jun 18, 2007 10:13 am
Has anyone come accross this before:
I've got a blaupunkt which i think is standard. Anyway at the weekend it suddenly displayed this on the LED:
'WAIT 1 H'
Which i'm guessing means wait 1 hour and i will start working again.
I did and it hasn't. :(
Any ideas lads? I sooo need my tunes :cry:
Ron
Utrinque Paratus
steve_weegie
Post by steve_weegie » Mon Jun 18, 2007 10:37 am
Sounds like its asking for a keycode. If i remember correctly, its got to be a 1hour wait with the ignition ON, then put the code in....
Ron
Post by Ron » Mon Jun 18, 2007 12:29 pm
Thanks,
Trouble is i don't have the manual.
Anyone know what the code is :?:
Ron
Utrinque Paratus
Post by jj » Mon Jun 18, 2007 12:31 pm
If you go to the Blaupunkt website you can put the model number in and download the manuals.
Post by Andy G » Mon Jun 18, 2007 12:32 pm
its most likely to be unit specific -suspect the factory might be able to help if yuo have the serial number for the unit?
Post by BiggestNizzy » Mon Jun 18, 2007 12:37 pm
jj wrote:If you go to the Blaupunkt website you can put the model number in and download the manuals.
Andy G wrote:its most likely to be unit specific -suspect the factory might be able to help if yuo have the serial number for the unit?
Sounds about right.
The code will be specific to the unit. You will have to contact the manufacturer or an agent and they will probably charge a couple of quid to get the code. Failing that you can get it decoded. I don't like that to be honest as the stereo is never really right after.
steve_weegie
Post by steve_weegie » Mon Jun 18, 2007 1:32 pm
The code us usually derived from the units serial number. If you've got the serial of the unit, post it up or PM me it & i'll "see what i can do"......
Ron
Post by Ron » Mon Jun 18, 2007 1:35 pm
Cheers guys,
Will have a look for the model number and try that.
Don't know why it did it in the first place.
Maybe it didn't appreciate my Take That CD :roll:
Ron
Utrinque Paratus
Post by robin » Mon Jun 18, 2007 1:46 pm
The code should also be on the original little plastic thing that came with the spare key ..
