I need to join steel to steel and can't be bothered with finding someone to weld it. has anyone every brazed or silver soldered? I have a small gas torch and they are only a couple of thin brackets onto a fuel rail (Brand new so no fuel in it!!)
Hard/silver soldering (FALC)
- BiggestNizzy
- Lawrence
- Jedi Master
Silver solder is a fab way of joining metals
The solder is quite pricey tho' and the flux is usually a powder type
For steel you need some firebricks for backing or similar and a blow lamp
Cut bits of solder and lay along the joints with flux powder then heat until the steel is cherry red and the solder runs into the joint, allow to cool
Jobs a good un
Jobs a good un
