Dead Alternator (I Think)
Just a quick question, I want to make sure I'm thinking straight before I spend the money, get under the car and take things to bits. I think my alternator is dead, brief details:
1. Charge light staying on.
2. Check battery voltage with engine off 12.5V
3. Car starts okay.
4. Check battery voltage with engine running, still 12.5V, turn lights on, drops slightly to 12.2V, lights don't seem to get brighter as I rev the engine.
5. Removed small two wire connector from Alternator, charge light was off (no surpirse as one of the small leads obviously carrys the charge light signal) checked the volatge across the ground and the +ve connection on the alternator, engine off = 12.5V engine running = 12.5V.
I can't see any reason for the above results other than a dead alternator, am I right, or have I missed something obvious.
Any thoughts would be welcome.
Thanks
Giles
3. Car starts okay.
Thanks
Giles
Quick update, has anyone got a spare S2 K series alternator I can beg, steal, borrow, rent etc., just been onto Elise parts and they won't have any until the end of August, I'll call murrays but I'm not hopeful.
Following Richard's advice, does anyone know if it is possible to buy just the regualtor, suddenly it's all looking a bit desperate for TT.
Giles
Giles
Rover dealers (Now all Kia) are worth a shot. I used to one in Dundee (Kia dealer that is) of all my bits up there I have also got Rover bits from other Kia dealers around the country too.
TBH most motor factors should be able to get them without difficulty
Giles, I found if you can get the details of the one fitted to the car and then ask for the same or an equlivelant, rather than asking for a Lotus Elise alternator, was much easier.
Fitting is awkward and you need to take the bootlid/engine cover off, just 4 bolts and spacer washers, so not hard.
Thanks Stephen, hopefully won't need it as following a few posts about motor factors I called Livingston autoparts and they should be able to help, just need the model numbers, also MMC have one, a bit expensive (no surprise) but I may go for it as the last one was not a Lotus part and didn't last too well.Giles,
I think my dad may have a one off a rover 214 which i could ask him to bring down to me. You wouldn't get it till the end of the week though.
Thanks for your help
Giles
Code: Select all
AndyG has an S2 alternator of an 8,000 mile S2 135R engine sitting in his garage that I am sure he would sell to you at a reasonable price ..
RobinCertainly is, it helped taking the boot lid off, also the heat sheild around the exhaust manifold and the floor panel under the engine bay.Fitting is awkward and you need to take the bootlid/engine cover off, just 4 bolts and spacer washers, so not hard.
Thanks for the advice
Giles
