CRP
CRP
I've just bought one....arrived today and I was straight out to fit it...
Jacked the car up
Undertray off
Now I realise the bolts don't look like they are coming off very easily and two in particular look a complete nightmare especially with my B&Q Plastic tool kit.
Sooooo,
Worth fitting the CRP?
Good mod?
I already have a sports exhuast which is quite loud but I was hoping the CRP would give it an even deeper note.
I'm going to have to get someone to fit it.
Jacked the car up
Undertray off
Sooooo,
Good mod?
I fitted mine just the other week. '99 car only one bolt was tricky but it was the one with the best access so no probs. Tried fitting the anti-tizz bracket and sheered a bolt, so not a bad idea getting someone else to do it.
Its fab tho, havn't had the stereo on since fitting it. Car sounds too good just can't stop listening to all the cool gurgles and stuff.
If its a deeper exhaust note (particularly with revs) your after then you want to fit this.
To be fair tho I have the Brooke Kensignton exhaust which was fairly quiet... until now.
Good luck
Scott
Good luck
Scott
- thinfourth
Cat Replacement Pipe...
Basically a foot of scaff-pole with a couple of flanges that fits in the exhaust system. Replaces the Cat on the car, meaning you save a bit of weight, gain a bit of power and make goooood noise
