Front splitter
Front splitter
Post by ExigeKen » Fri Jun 01, 2007 2:05 am
Oops hit a dead deer on the road at Bearsden late tonight and it has damaged the front splitter. It has cracked into two pieces but stayed on the car. Can this be repaired or do I need a new splitter and is this a big job :?: :cry:
Amazingly despite cracking my number plate it has stayed on the car. Thanks again Campbell for the bolt and double sided carpet tape approach definately can take a real bashing. :thumbsup
Post by ExigeKen » Fri Jun 01, 2007 8:01 am
No not too much really just the one crack on the splitter and it is slightly out of alignment. Just the signs of a well used Lotus I guess :wink:
Post by Rich H » Fri Jun 01, 2007 8:06 am
Pics?
Should be repairable if it's not too bad.
Post by ExigeKen » Fri Jun 01, 2007 8:09 am
RICHARDHUMBLE wrote:Pics?
OK I will do that tomorrow it doesn't look bad at all really. Thanks.
Post by alicrozier » Fri Jun 01, 2007 8:51 am
I heard that the Exige splitter is very cheap to replace (although definition of cheap may be relative from MMC). Almost a disposable item... :?:
Worth checking vs cost of repair.
Post by ed » Fri Jun 01, 2007 9:23 am
:withstupid I believe that they are around 70 notes! HTH cheers Ed
Post by ExigeKen » Fri Jun 01, 2007 11:12 am
ed wrote::withstupid I believe that they are around 70 notes! HTH cheers Ed
Cool sounds like a new one it should be then.
:cheers Ken.
Brunty
Post by Brunty » Sat Jun 02, 2007 11:10 am
Did you pick up the deer for Tut?
Brunty
Post by ExigeKen » Sat Jun 02, 2007 4:01 pm
Brunty wrote:Did you pick up the deer for Tut?
Brunty
only the bits stuck to my car :lol:
ninja
Post by ninja » Mon Jun 04, 2007 10:31 pm
go to a motor cycle dealer and buy a fairing repair kit.
http://www.halfords.com/webapp/wcs/stor ... ryrn_31336
or you can buy from halfrauds for £18
it's an easy job, if you're sturuggling i'll pop over and do it for you - i've smashed up and repaired my ducati far too often for my own good and i've become fairly proficient in the art of plastic repair!
ninja :drive
