Elise - Honda Engine - Gearbox
Daveb
Post by Daveb » Mon May 21, 2007 11:22 am
I know there are guys who are using Honda engines in their Elises.
Do these use the Honda or Rover gearbox?
Would the rover gearbox fit on the honda engine?
Re: Elise - Honda Engine - Gearbox
Post by GregR » Mon May 21, 2007 1:03 pm
Hell no, not least of all because its missing a ratio!
Post by robin » Mon May 21, 2007 1:14 pm
I think the biggest problem is that the honda engine rotates the other way from the rover (though this is hearsay - I don't actually know for sure which way it turns).
The duratec conversions use the rover box, which should in theory make for a cheaper conversion (no issues with driveshafts, clutch and gear linkages to work out).
Post by woody » Mon May 21, 2007 1:44 pm
robin wrote:I think the biggest problem is that the honda engine rotates the other way from the rover (though this is hearsay - I don't actually know for sure which way it turns).
I thought that was the older generation of honda engines that sat the other way round in the bay, ie. the engine would be on the passenger side. Surely (like a FWD A series) if the Honda sits on the RHS and rotates the other way it'd need an extra gear set in the box (eating more power) or it'd have 6 reverse gears and one forward?
Post by robin » Mon May 21, 2007 2:01 pm
You are no doubt correct ...
andysc
Post by andysc » Thu May 24, 2007 3:40 pm
honda gearbox
Elise S1, DIY Honda K20A2(N/A)/DTA Install,
Currently undergoing conversion to target 450bhp
Merc E55 AMG - (exocet missile in a suit)
Nissan Navara. - (Snow plow)
gsxr thou K6.
Post by campbell » Fri May 25, 2007 1:42 am
Well obviously the Honda rotates the other way because when you look at it in the engine bay the "Honda VTEC" badge is upside down
