Braided Brake Hoses
Braided Brake Hoses
Post by DDtB » Tue Apr 17, 2007 11:20 am
Don't suppose anyone knows where I might find a guide on how to fit these on an S1.... elise faq doesn't seem to have one... :?
cheers
:D
Post by ed » Tue Apr 17, 2007 11:21 am
You'll need more than just those! :wink: :P
Post by DDtB » Tue Apr 17, 2007 11:23 am
ed wrote:You'll need more than just those! :wink: :P
It's just a hypothetical .... honest... :roll:
hiscot
Post by hiscot » Tue Apr 17, 2007 11:24 am
make sure you have a easy bleed, makes life easy
my very early S1 required the windscreen support low down modding to get access to the front pipes with a spanner
their is a online guide
http://www.elisenet.com/
there you go
Post by Rich H » Tue Apr 17, 2007 12:02 pm
I had to chop holes in the crash structure to get to the inboard front joints...
Post by DDtB » Tue Apr 17, 2007 12:08 pm
Mines a 99 so hopefully won't need the windscreen support mod....
if I was to ever attempt it... :wink:
:D
Post by Rich H » Tue Apr 17, 2007 12:26 pm
Stop being a mincer. Fit the top of the hose in place and bleed until fluid pishes out of the bottom of the line, then attach to calliper. Het presto new brake lines!
bazzam111
Post by bazzam111 » Tue Apr 17, 2007 12:43 pm
...and don't forget to bleed the clutch at the same time to renew all the hydraulic fluid in the system. Used my Dremmel to cut holes in the crash structure, worked a treat. Now got a nice 'solid' brake pedal :thumbsup
S1 'Std' Azure Blue (well nearly standard......)
Disco D4 (shiney spec)
Defender 90 (dirty spec)
Post by Rich H » Tue Apr 17, 2007 12:52 pm
What he said :thumbsup
Your still a mincer though :P
Post by DDtB » Tue Apr 17, 2007 12:56 pm
:finger
Post by Rich H » Tue Apr 17, 2007 1:00 pm
Top tip though when you do it twist the brake line so you can screw it into the caliper without any twist left in it (IYKWIM) otherwise it will undo its self! :shock:
Post by DDtB » Tue Apr 17, 2007 1:04 pm
RICHARDHUMBLE wrote:Top tip though when you do it twist the brake line so you can screw it into the caliper without any twist left in it (IYKWIM) otherwise it will undo its self! :shock:
Did you hear that ok Mac ?? :wink:
Post by Rich H » Tue Apr 17, 2007 1:15 pm
I ended up taking the caliper off and screwing the caliper onto the brake line... :roll:
Post by ed » Tue Apr 17, 2007 1:18 pm
:lol: Im sure mac is far too busy looking for his brave pills to have time for fitting your hoses?! :P :wink:
Post by mac » Tue Apr 17, 2007 2:47 pm
I'm out clay bar-ing the S2 :wink:
Then I need to get a mirror finish on the rear of the caterham so Ed can see what part is falling of his car
Mac :D
