Instant Karma - Doh! content
Post by woody » Wed Apr 04, 2007 4:05 pm
Spent sunday aft hungover and gave the car a clay/polish/wax etc... The car has however taken exception to this dramatically changed state of affairs and now appears to be running lean :(
It'll fire up fine and runs fine at low engine speeds (<3K) open it up though and there's no power and lots of hesitation & stuttering. No signs of HGF. Plugs are out, and along with the tailpipes, their normally sooty black running a bit too rich look has been replaced with a chalky whiteness.
Noticed a new rattle last week and dissmisssed it as being the exhaust, but with hindsight it could be pinking :oops:
Other than the car being clean nothing elses has been touched, had a look over it and there's nothing obvious. Is the fuel filter a possibility, or a sensor? I'm lost with these beyond carb's and points mostly :| Any ideas/help gratefully received.
Post by mac » Wed Apr 04, 2007 5:24 pm
Faulty MAP or TPS sensor?
Disconnect one then the other to see if there's any difference.
Post by robin » Wed Apr 04, 2007 11:47 pm
I agree - it's probably lost the TPS and doesn't realise you are opening the throttle ...
Then again it's a sport 160, so different ECU, so cannot be sure.
Post by woody » Thu Apr 05, 2007 8:00 pm
Disconnected both - engnie just died.
Then tried resetting the TPS, but no joy.
Has been suggested to me by a tame RAC man that it might be the ecu temp sensor? Will get a newone tomorrow.
Post by mac » Fri Apr 06, 2007 12:26 am
Disconnect one at a time.
The one that doesn't affect is probably the dodgy one :-)
Post by woody » Fri Apr 06, 2007 11:04 am
Should have put that a bit better - i disconnected one at a time! Also tested the ICAV but it's fine.
Tray off and test the lambda tonight and fit the new ecu temp sender if partco have one.
Post by mac » Fri Apr 06, 2007 11:10 am
So when you remove either one the engine dies?
Sounds like it's not one of those then which is strange.
Post by woody » Sun Apr 08, 2007 9:17 pm
stuck on a TPS from the scrappy today and the car ran a lot worse.
Then put mine on and it still wasn't right. Think both could be u/s, and i'll need to try a new one. The car's running with the TPS disconnected now before and after trying the replacement one in, and with it in.
:? :( :roll:
Post by woody » Thu Apr 12, 2007 9:44 am
Eliseparts dont do mail runs on a wednesday :rage :chainsaw
So the part i ordered on tuesday because i thought 'oh elise parts it'll be here quick as a flash' won't be here until at least tomorrow :roll:
fcuk good weather, mumble.....
Post by ExigeKen » Thu Apr 12, 2007 9:55 am
No luck Woody hopefully you will be back on the road very soon. :drive
Post by woody » Fri Apr 13, 2007 4:01 pm
the news good and bad:
The metal bits in the exhaust are bits of gubbed cat (lucky then that i bought richardhumble's decat last week) wasn't sure if i had bits or piston or not :)
Not running well issues weren't the TPS; with the new one fitted there's no difference :(
Post by woody » Mon Apr 16, 2007 7:30 pm
well thats it sorted :D :D :D
The HT lead from the coil to the dizzy cap had chaffed against a bracket - and i've had new HT leads sitting for months :? :oops: :lol:
I only noticed the small bit of chaffing when i took the exhaust off to check the state of the cat on friday, and couldn't try the new lead until i'd got nuts & bolts at work today to fit the decat (bit of grinding action put paid to the cat studs :twisted: )
It was always bound to be somthing silly.
:drive
