S2 - Driving Lamp Brackets - Fitting them ?
a4drk
Post by a4drk » Fri Mar 23, 2007 7:09 pm
I'm changing the Bug Eye Projector lights to the bigger style.
On the old bracket, there are 2 x self tappers going up the way into the body work.
The new brackets are in 2 pieces & attach in a different place.
One attaches to the "black inner area" - looks like it bolts thro 2 holes already there.
Do I need to take the clam off to get into this?
anyone done this before?
David
:roll:
a4drk
Post by a4drk » Sun Mar 25, 2007 10:47 pm
Apparently its a clam off jobbie.
So, i am thinking of ways round this.
The only solution i can come up with is the Spring toggles which you fit into Gyproc walls.
Theoretically it should work..................
David
bertieduff
Post by bertieduff » Thu Mar 29, 2007 2:15 am
This the offending article? IIRC it's clam off to get to the top bolts on the bracket.
Btw if they are OEM i'd give them a lick of hammerite- mine needed replaced at 2yo :roll:
a4drk
Post by a4drk » Thu Mar 29, 2007 3:18 pm
Excellent - great pic.
However.
There is an advert on Fleabay advertising these...........
I've asked Murrays in Edinburgh if they do a 2nd type...
by the way, its a different width from the bug eye projectors.
David
dr al
Post by dr al » Thu Mar 29, 2007 4:04 pm
I had the front clam off mine last month, but didn't remove the old bug-eye lamp brackets, cos as well as the bolts/screws, they were held on by a big (very strong) adhesive pads - bear this in mind!
will the new ones not fit in the old brackets??
A.
a4drk
Post by a4drk » Thu Mar 29, 2007 4:17 pm
Nope, they are wider by about 15to20mm
David
PS - I cannae post pictures!
Post by ed » Thu Mar 29, 2007 4:22 pm
See here for top tips, cheers Ed
a4drk
Post by a4drk » Thu Mar 29, 2007 9:23 pm
Excellent! - sorted......
David
:wink:
MacK
Post by MacK » Fri Mar 30, 2007 11:50 am
Can you not take the lamp of the bracket, and use the existing bracket, or modify it in postion.
