Exige S ECU?
ScottyB
Exige S ECU?
Post by ScottyB » Thu Jan 25, 2007 6:04 am
Which ECU does the European S2 Super Charged Exige have? Is it the same as the 2005 Fed Toyota Engined S2 or the newer 2006 Fed Toyota Engined ECU?
Picture of 2005 Fed ECU
Picture of 2006 Fed ECU
jamie
Post by jamie » Fri Jan 26, 2007 8:44 am
I am guessing you are looking to install an SC in your car and an S ECU would sort out the ECU part of the equation? If so you are better off with something like the FF standalone etc
ScottyB
Post by ScottyB » Fri Jan 26, 2007 1:26 pm
Yes I am looking to install a SC, but I want to use a stock ECU. If I have to I can always change some parameters in the Stock Map, but figure why reinvent the entire wheel when Lotus has already done 99% of the mapping.
So the question still remains, which ECU is in the European ExigeS?
Post by ed » Fri Jan 26, 2007 1:30 pm
For me atleast that first pic doesnt work..... :?
To be honest i can only think of one person on here, who rarely posts, who has an S. You may get a better response from the likes of http://www.exiges.com. :)
HTH cheers Ed
jamie
Post by jamie » Fri Jan 26, 2007 3:43 pm
I can tell you from personal experience that there are very very few peeps with the skills to cracking the Lotus ECU full stop (Bemani was one of them) Why do you think FF, Tripoint all went the piggy back route?
A search on ET will provide you with a ton of info on this subject also try Franks sight more monkey they have quite a few SC pioneers
ScottyB
Post by ScottyB » Fri Jan 26, 2007 4:25 pm
The Ecu Code has been cracked and can be altered. No need for a piggy back.
Lawrence
Post by Lawrence » Fri Jan 26, 2007 7:30 pm
ScottyB wrote:The Ecu Code has been cracked and can be altered. No need for a piggy back.
cool tell us more
ScottyB
Post by ScottyB » Fri Jan 26, 2007 7:44 pm
go to moremonkey.com and you will see for yourself.
