Rotational noise front left brake, goes when braking
- Victor Meldrew
Sounds like what I get every time I leave the car at the work car park for two weeks.
The rear pads have a groove accross the face, after a while this groove can fill up with rust deposits and the brakes sound and feel horrendous. You have to take out the pads and clean out the slots and then there almost as good as new.
If your using your car regularly, I wouldnt think you would have this problem. I think it only happens with me because it sits idle for two weeks every month.
Take the pads out and check the groove... then take the car out and thrash the >>>? out of it for a hundred miles or so. As if you need an excuse anyway...
- Victor Meldrew
When the brakes are applied the disk and pads cannot move side-to-side and the pads are locked against the top of the caliper, so any noise caused by rattling or vibration is probably deadened.Sanjoy wrote:MMCs make a diff here ?why would the noise go when applying the brakes though ?
When the surface of the disk is rough (caused by rust on steel disks and, err, don't know on MMC disks - perhaps salt crystals or some kind of alloy corrosion) then that layer will make a hiss/rasp sound when just glancing the pad surface (a bit like if you just touch something to a bench grinder you get a hiss).
If it's corrosion on the disks I would expect 99% of the noise to go away for good the first time you do a couple of quick stops from high speed. If it doesn't I would be looking for a stuck piston or seized rear caliper side - this will cause low brake pressure on one of the 8 surfaces and thus this surface won't get cleaned.
- bertieduff
Defo think that it is the pads hitting the disk as at lower speeds when I hear it tapping I can make it do a final tap by tapping the brakes.robin wrote:Twang is often the springs on the brake pads - I know you've checked, but might be worth double checking!
The other thing it could be is the disk touching the caliper (this happened to Tut, IIRC).
Okay gonna sound dumb now but the spring is a return spring to pull the padds back when the brake pedal is released ?
