stack reset
- tuscan_thunder
stack reset
I suffered a 'breakdown' today which we (by which I mean Mr Crozier via the medium of the telephone) have tracked back to the battery failing due to the alternator failing or suffering a loose connection.
The problem remaining is that the stack shows 4000rpm and 50mph even when the engine and igntion are off. When I fire up, the tacho jumps by the required amount. I.E, the dash thinks that 4000rpm is actually zero.
When the ignition is turned on it does the wee dance as it should, but only back to about 3800 on the display.
How do I reset the dash?
Thanks in advance
John
Thanks in advance
John
Mair throttle, less brake
- tuscan_thunder
- The_Rossatron
There is a way to reset it by leaving the drivers door opening and turning the key back and forth in the ignition a few times. If you give SELOC a quick search you'll find the exact sequence there.
http://www.allflashnocash.com
or you could go hereThe_Rossatron wrote:There is a way to reset it by leaving the drivers door opening and turning the key back and forth in the ignition a few times. If you give SELOC a quick search you'll find the exact sequence there.
http://www.scottishelises.com/phpbb/vie ... sc&start=0
Sounds like the same thing and it sorted mine out.
Given that turning the key on and off a few times sorts it anyway and given that there is no connection from the driver's door switch to the stack, I suspect the driver's door bit is not requiredThe_Rossatron wrote:There is a way to reset it by leaving the drivers door opening and turning the key back and forth in the ignition a few times. If you give SELOC a quick search you'll find the exact sequence there.
Then again, I might be wrong - anyone actually worked out whether or not the door has anything to do with it.
- colin adams
I've heard that you need to press the little switch, whilst turning on and off the ignition with the door open, dress in your wife/girlfriend/sisters/mothers Sunday best, whilstling showtunes.
HTH
PS: Has no one (other than Robin) noticed that every time you turn the ignition on that the needles "dance"? Let them dance enough and they will return to the bottom
HTH
