Geo Settings for s2
- craigs135s
Geo Settings for s2
Need to get the Geo looked at on the s2. what should it be set at?
Craig
Craig
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
- craigs135s
does the fact that your ride height is lower than standard have an effect on what geometry setting should be?
I was thinking on playing around with settings too.
- craigs135s
no chance.
i asked him at the time and he didnt know what a geometry check was!
i'll need to trace it down through all of the SELOC owners.
- craigs135s
no - that was 2 owners ago!
the guy that i bought it from only had it from March 06 to Sept 06... and did feck all with it - apart from add a few thousand miles and wear the advans down!
I've U2U'd the previous SELOC owner
What front tyre width do you have? If 175 then I agree with McApe that leaving it standard is just fine until you intend doing lots of track days.
If you have 195 on the front then I think you could happily go as much as -0.3 degrees without taking anything away from road handling.
If you're going down the R tyre route you'll want as much front camber as you can get - on the S2 you often cannot get more than about -0.4 without machining the plinths.
-1.6 is way too much for road tyres.
I am running -0.4 with the R tyres (I would have liked a little more but couldn't get it without machining) - even so it doesn't seem to be too slow
But each to his own - I am sure other people have all sorts of settings that suit them, some with more camber, some with less
