Mair go!
tuscan_thunder
Mair go!
Post by tuscan_thunder » Mon Dec 04, 2006 12:32 pm
My car's got the 135 engine. It has a 57i K&N which adds noise but I suspect no power.
It has a Janspeed exhaust which is on its last legs.
The car's been feeling a little flat recently, not quite so keen as it used to feel. It seems to take a wee while to really get going and even when it does it never seems to pull with the conviction it used to. Could be my imagination though.....(It's always on decent fuel and the air filter's clean)
It's due an MoT in January so I'll wait til that's past before doing any work.
I will replace: Fuel filters, plugs and plug leads and probably change the front brakes and fit braided lines as well as the usual service items (incl cambelt).
I need a new exhaust and I think I'll decat the car too.
Being a tight Scot, I want a cheap exhaust! If it's loud then that's all the better! Will a decat pipe, like an Eliseparts one, fit any exhaust?
Any exhaust advice will be welcomed as will any ideas as to how to get a wee bit more go without spending mental money.
All advice welcomed!
john
Mair throttle, less brake
Post by mac » Mon Dec 04, 2006 12:44 pm
Did you buy the janspeed?
If it's a 304stainless steel one it should have a lifetime warrenty.
tuscan_thunder
Post by tuscan_thunder » Mon Dec 04, 2006 12:49 pm
it was on the car when I got it - it's cracked in the U-shaped bit and has been welded but it's nae helping matters. I guess it's stainless but I'm not sure. There's no invoice for it in my folder of documents though...
hiscot
Post by hiscot » Mon Dec 04, 2006 1:05 pm
I fitted a s/h Komo - tech its huge but is an asorb type not baffled I understand theres less restriction so releases more horse power but whilst quiet with the cat on its quite noisy without
and the packing requires replacing every so often ( thats how I bourght it I repacked it )
tuscan_thunder
Post by tuscan_thunder » Mon Dec 04, 2006 1:51 pm
hiscot wrote:I fitted a s/h Komo - tech its huge but is an asorb type not baffled I understand theres less restriction so releases more horse power but whilst quiet with the cat on its quite noisy without
tell me more! I'm interested.
Where did you get it from, how much was it, is it easy to fit?
Baggy
Post by Baggy » Mon Dec 04, 2006 2:01 pm
Don't know how effects the K-series cos mine doesn't have one but new dizzy cap & rotor arm used to make a real difference to my old scirocco..
Baggy
Silver S1 111s
The Deen
hiscot
Post by hiscot » Mon Dec 04, 2006 2:07 pm
I got mine second hand from germany because it wanted repacking
just saying I believe a absorbstion type is suposed to release more power and thats the type I went for
