Turning off the heating ?
Julien
Post by Julien » Tue Aug 19, 2025 11:21 am
Hello,
We're going on a road trip to the south of España at the beginning of September, and I'm wondering if we can turn off the heating, because even on cold, hot air ends up coming through the air ducts, and the whole space under the dashboard is very hot.
From what I understand from the diagram, hot water circulates constantly in the heating circuit.
Has anyone tried installing a valve on this circuit ?
Re: Turning off the heating ?
Post by Stephen » Tue Aug 19, 2025 11:30 am
I wouldn't mess with it but it might be worth checking that the levers / cables are correctly operating the diverter flaps.
Tim S
Post by Tim S » Tue Aug 19, 2025 3:50 pm
And I always reckoned that a lot of the heat soak into the cabin comes from the main coolant pipes in the sills (i.e. the ones to/from the radiator) - so there might be limited benefit anyway
Post by Stephen » Tue Aug 19, 2025 5:12 pm
Also through the bulkhead behind the seats and heat is also drawn forward if you have the roof off.
