S1 battery
2F45T4U
S1 battery
Post by 2F45T4U » Mon Feb 19, 2024 3:59 pm
I cant remember what ones fit and what doesnt.
Even though theyre 063, if i remember right not all of the cases fit in the hole.
Ive got a Lion at the moment
Does a Bosch s4 fit? ECP are pricing best so far on this..
Thanks
Re: S1 battery
Post by rossybee » Mon Feb 19, 2024 4:13 pm
Try Tayna online - found them to be excellent price and quick service
philthy
Re: S1 battery
Post by philthy » Tue Feb 20, 2024 12:44 pm
I’ve just taken a Bosch S4 out and replaced it with a halfords 063
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
2F45T4U
Re: S1 battery
Post by 2F45T4U » Tue Feb 20, 2024 12:53 pm
Cool. Ill take it that it fits.
Thanks
Re: S1 battery
Post by woody » Wed Feb 21, 2024 2:51 pm
063, make sure it has a good handle.
colgy
Re: S1 battery
Post by colgy » Wed Feb 21, 2024 9:30 pm
I bought this from Tanya recently:
Bosch Car Battery 12V 52Ah Type 063 S5001
Re: S1 battery
Post by rossybee » Wed Feb 21, 2024 10:28 pm
How easy is changing one out?
It's kinda buried down low.....mine isn't great, but fine on the trickle charger
2F45T4U
Re: S1 battery
Post by 2F45T4U » Wed Feb 21, 2024 10:31 pm
10mins. Its easy. Just a bit of a footer.
10mm spanners and a socket
Re: S1 battery
Post by rossybee » Wed Feb 21, 2024 11:08 pm
Cheers. I did notice the skoosher reservoir lifts up and out the way easily whilst jump starting once when not on trickle
2F45T4U
Re: S1 battery
Post by 2F45T4U » Wed Feb 21, 2024 11:17 pm
Ye. If you're careful, you dont need to remove the radiator surround.
The retaining bolt for the clamp has a very thin head, so dont loose it.
Re: S1 battery
Post by Dominic » Wed Feb 28, 2024 3:10 pm
If ordering from Tanya, use the code NUMBER27YT for a further 5% off :cheers
Re: S1 battery
Post by Ferg » Sat Jul 27, 2024 2:12 pm
Just changed my battery. The one Halfords stocked was a high capacity and didn't quite fit. I had to trim 10mm off the battery bracket to make it fit. Worth doing as the new battery has a bigger amp rating.
