S1 rear window fitting
SteveJB
Post by SteveJB » Tue Jun 07, 2022 6:09 pm
Refitting rear window after a lengthy rebuild and I bought a replacement seal some time ago expecting it to be the circular tubing that goes round the inside of the window. I was sent a square seal (about 1cm across) which is only just over the length of the window. Should this sit below or above the window or have I been sent the wrong seal? Had it too long to send back.
Re: S1 rear window fitting
Post by Stephen » Tue Jun 07, 2022 6:59 pm
Does it not stick on to the perimeter of the window cabin side?
Post by Shug » Mon Jun 27, 2022 11:12 am
If it's the old Shugmobile (hello Steve!) then it'll have the later sloped rear window to stop the weird headlight reflections in the mirror. Can't honestly remember how the seal fits on it, but if you've got the seal for bare glass, might be wrong.
Post by Ferg » Thu Jun 30, 2022 8:00 am
The one from EP is a half moon seal like you expected, and it sticks to the cabin side of the casing. I can take pictures if it would help.
Might be that your seal is for the window and casing to sit on? Again, comparing to an existing one might be best.
2F45T4U
Post by 2F45T4U » Fri Jul 01, 2022 8:06 am
I pulled mine off last night to have a look at this.
I have the sloping window. The seal runs the circumference of the window edge and is stuck on the face of the glass on the cockpit side.
Seal is approx 12mm in diameter, round/oval section.
I took pics if you want them emailed.
SteveJB
Post by SteveJB » Sun Jul 17, 2022 6:41 pm
Thanks for the advice. Got it fitted now.
