CAT Orientation
111Robin
CAT Orientation
Post by 111Robin » Sat Feb 23, 2019 4:39 pm
I removed the CAT and exhaust a couple of weeks ago, and now have the new Larini exhaust to fit. I forgot to note the orientation of the cat before I removed it, can anyone advise ?. It's the original item, heat shield on one side, no markings suggesting flow direction.
Kinger
Re: CAT Orientation
Post by Kinger » Sat Feb 23, 2019 6:56 pm
I just changed mine on the S1 and I’m sure orientation of the flanges means it can only go on one way.
111Robin
Re: CAT Orientation
Post by 111Robin » Sat Feb 23, 2019 7:14 pm
Cheers, I should have offered it up first, probably very obvious.
Re: CAT Orientation
Post by Ferg » Sat Feb 23, 2019 7:15 pm
Yep, as Kinger says, it only goes on one way. I worried about the same thing first time I did it. It makes sense when you see it in place 👍
111Robin
Re: CAT Orientation
Post by 111Robin » Sat Feb 23, 2019 7:19 pm
Re: CAT Orientation
Post by campbell » Sat Feb 23, 2019 7:33 pm
Audio clip of sound required
