S3 suspension options
Post by robin » Sun Nov 25, 2018 6:48 pm
The suspension on my elise is a bit tired.
My options are just to replace with bilstein or look at nitrons etc.
Was thinking of getting Tim s refurbed, but s2k not the same as S3 apparently.
My use is mostly track use.
Who's fitted what in recent years, and how have you found it?
BigD
Re: S3 suspension options
Post by BigD » Sun Nov 25, 2018 7:51 pm
I had Nitron street series on my s2 and it was a huge improvement on the bilsteins.
Considering the buttons for the v6 too.
Post by campbell » Mon Nov 26, 2018 12:36 am
Welcome to try out the adjustable Bilsteins on mine too
Post by robin » Mon Nov 26, 2018 6:49 pm
If by try out you mean 20 laps of the ring, I'm in :-)
Post by campbell » Mon Nov 26, 2018 6:50 pm
I can but dream
Post by Mikie711 » Mon Nov 26, 2018 7:19 pm
For mainly track work it has to be Nitron's all the way or Ohlins TTX if your feeling flush :)
IanD
Post by IanD » Mon Nov 26, 2018 9:45 pm
Went in my S2 from Bilstein to Nitron 40 one way.
My bilstein must have been past their best but still acceptable, great change in feel and turn in even with same suspension settings for road use.
Kept them only couple of clicks off soft setting most of time so ride was similar but control much better.
Just watch service costs as they do seem to need serviced/rebuilt. A service that turns into a rebuild can be close to replacement costs for NTR 40.
White Porsche man
2010 Boxster Spyder
1993 968 ClubSport - see it @https://youtu.be/8PnI0VE1B54 SOLD
Post by Mike Scib » Mon Nov 26, 2018 11:06 pm
Would the Ohlins really make that much difference?
Worth changing the front ARB to, Robin?
Post by Mikie711 » Mon Nov 26, 2018 11:49 pm
I like Ohlins kit, they are/were owned by Yamaha and have massive presence in race especially bikes. The TTX on the V6 Cup were something special and were 2-way adjustable for bump and rebound. The only issue with them on the Exige was that you had to remove the rear wheels to adjust them as you couldn't reach the adjuster knobs.
They were an option for both the road and race Exige Cup R so a step up from Nitrons.
Post by robin » Mon Nov 26, 2018 11:53 pm
I like zero adjustment 😂 wouldn't have gone for streets because they sound lame, but if they were good enough for big d they will be good enough for me 😂
No way ohlins, too many knobs to adjust. How would I ever set it up.
ARB might be good idea too and can easily fit later.
Thanks all!
Post by woody » Tue Nov 27, 2018 12:04 am
Quantum then? They do Non adjustable versions and can be specced with Track specific springs. 2 year warranty is twice the Nitron offer iirc.
Post by robin » Tue Nov 27, 2018 8:03 am
Has anyone got first hand experience of quantum, though? I keep dithering about them because I don't think I know anyone who has or is using them.
Need more cars 😊
Post by campbell » Tue Nov 27, 2018 8:15 am
Time to ask SELOC...
Post by woody » Tue Nov 27, 2018 8:53 am
Need more cars 😊
I have a set.... They've not been on the car. Scuffers highly reccomended them for what it's worth.
Must be a few people running them given they're Elise Parts main damper for sale.
Rosssco
Post by Rosssco » Tue Nov 27, 2018 3:02 pm
Need more cars 😊
I dithered over them (Quantum Zero's) for about 3 years, then put them on my VX220. They were good. Not quite as road-friendly as the Exige-spec Bilsteins I had before (hence why I switched back) but a good compromise for an occasional use road car with the odd track day thrown in. They also allow you to lower the car a bit, but obviously more than 15-20mm has its own drawbacks.
NSS felt very similar on the road with regards to compliance and composure, and have the damper adjustment.
Like you, I dont really like too many adjustable things (I have adjustable ARB's and those along with changing tyre pressures, allows me to tweak front / rear balance plenty), as I like to get to know how the car reacts and know it will continue to react in a consistant manner. Probably a road setting and a track setting only would be fine.
VX220 SC
M135i
Parajet V3 Moster 185
