Headlight issue - Motorbike rather than Lotus
Post by ed » Fri Nov 09, 2018 5:55 pm
One for Robin perhaps.....
I am having issues with my bike headlight. (CB500F Honda)
At the moment at low revs and low speed the headlight cuts out occasionally. Higher speed it never happens. I do not believe it is a loose connection.
My bike headlight has a relay that kills the power to the headlight when the ignition is pressed. Could a faulty relay kill the power during low speed low rev scenarios? :scratch
Re: Headlight issue - Motorbike rather than Lotus
Post by robin » Sat Nov 10, 2018 3:04 pm
My guess is that your battery is dying. When the alternator is at low revs its output drops off. Normally the battery would keep the light on anyway, but if it's a bit crap it might not be able to (could be the relay dropping out for pretty much the same reason).
Happy to take a look if you want to pop round one day/evening.
Post by mckeann » Sat Nov 10, 2018 4:57 pm
Honda Regulator Rectifiers are notoriously crap so may not be outputting 14V to the battery.
Give Davie at bells burn a calll, he might be able to diagnose over the phone if it’s a common fault
Post by ed » Mon Nov 12, 2018 5:02 pm
Thanks both, Bike going in for a service next week so ill get him to look at it. :thumbsup
