cooling system
ferg f
cooling system
Post by ferg f » Fri Jun 29, 2018 6:49 am
Hi all,
Can someone give some advise please.
Have a "10" plate 1.6 Elise.
Car had a new radiator fitted by Murray motors, last September (approx).
The water temperature seems to sit around 88°C to 91°C, doesn't matter if around the town or a fast run on the back roads..... until yesterday, got stuck in the most horrendous traffic on the M8, the temperature got to 98°C when i jumped to the hard shoulder and let her cool, after 20 minutes the traffic was moving a little better, well it was moving at least and i continued with the temperature not going above 92°C, anyone know when the fans should be cutting in? As they hadn't cut n at the 98°C!!!!
The run home was fine, M77 and a "quick" run down the back roads to home and she never went above 91°C
Any advise would be great.
Cheers - ferg
rawsco
Re: cooling system
Post by rawsco » Fri Jun 29, 2018 8:15 am
Doubt I’d be worried, hot day, low airflow. Don’t think the fans really start to go at it till 102 which will bring it back down to mid 90s
Rawsco
2021 - Tesla M3LR
2019 - Exige 410
graeme
Re: cooling system
Post by graeme » Fri Jun 29, 2018 8:22 am
As above, nothing to worry about. Fan cut-in is definitely higher than 98C.
Stevoraith
Re: cooling system
Post by Stevoraith » Fri Jun 29, 2018 11:30 am
I remember panicking the first time I was stuck in traffic on a hot day too.
As mentioned I'm sure the fan kick-in point is at 101/102, remember the coolant in your engine won't boil at 100C, it's more like 106 IIRC so it was in no danger at 98C.
VX220 2.2 - Gone
rawsco
Re: cooling system
Post by rawsco » Fri Jun 29, 2018 1:24 pm
Just wait till you get the steam pouring out the radiator on a coldish wet day, you’ll sh*t yourself then.
Rawsco
2021 - Tesla M3LR
2019 - Exige 410
rawsco
Re: cooling system
^ also normal
Rawsco
2021 - Tesla M3LR
2019 - Exige 410
Re: cooling system
Post by campbell » Fri Jun 29, 2018 1:50 pm
Start it idling at home while you wash it and listen for the fan cutting in. Around 100 ish.
If it does boil up, start with fan fuse
ferg f
Re: cooling system
Post by ferg f » Fri Jun 29, 2018 1:51 pm
Thanks for the replies fellas, i guess i was panicking.
It is a new radiator as after a month of ownership the end tanks let go so i guess i am fine, i was just a little worried that the fans hadn't come on.
Stevoraith
Re: cooling system
Post by Stevoraith » Fri Jun 29, 2018 2:30 pm
Forgot about that one! :D
VX220 2.2 - Gone
neil
Re: cooling system
Post by neil » Sat Jun 30, 2018 6:34 pm
The coolant's meant to be good to 120. At 110 the temperature readout will start flashing, and at 111 it'll beep too, so 98 is nothing to worry about.
Exige V6
ferg f
Re: cooling system
Post by ferg f » Sun Jul 01, 2018 6:52 am
Cheers for all the info fellas, guess I was being overly cautious.
