FFS... sticking switches....... Ahrrrrrrr...
- Victor Meldrew
Has anyone else spent 20 mins trying to switch off there side lights...... what a pain.
S1 switches are from a peugeot ? Anyone know what model or an easy way to repair/refurbish the ones that are in already.
The only one that doesnt stick is my main beam, because its used everyday, the rest dont get touched so they have siezed up and stick in when you operate them, takes a good ten mins of vigourous poking to get them to pop out. (still talking switches here Shug before you start)
The unused button, is that a real one or a fake with no contacts?
Is there an alternative toggle switch that might fit? Always fancied putting an extra 12v socket in the unused slot.
John
Mine are/were exactly the same. Age and dirt does it. Some are the same as the Pug, but not all, and they have different pin arrangements, so you are stuck with Lotus ones I think for two. I was given a collection of spares and was able to use two of them as replacements, and I put a hazard one into the blank socket.
My sidelight switch has gone again, so I just do not use it, just use the main dipped if I need lights on during the day.
The end one is a dummy switch, but it is plugged into a wired connector, so you can fit a starter button or fag lighter with appropriate wiring.
- Victor Meldrew
John
You carefully prize off the black cover, and then you will see mastic covering two screws on the front. Prize this out for access, and I think there may also be two more underneath the front edge. Then carefully prize out the aluminium switch surround.
It is worthwhile disconnecting the battery as it is easy to get a short when you are unplugging/plugging.
I have a file with instructions that I will post as an attachment on SE1.
