215 tyres when 225 is the norm
Post by campbell » Wed Nov 16, 2016 3:35 pm
Have the chance of a set of pre-loved (!) winter tyres for the Octavia. But it currently runs 225/45 17 just now. These are 215/45 17.
So I make that about 5mm less on rolling radius. Is this a big enough impact on gearing or other side effects to cause me to abandon?
Re: 215 tyres when 225 is the norm
Post by Sanjøy » Wed Nov 16, 2016 4:11 pm
I am sure there is a site that calculates if they will fit, normally its the other way round so you can understand if you can stretch them.
Post by tut » Wed Nov 16, 2016 4:16 pm
Does the width make a radial difference if they are both 45?
Post by campbell » Wed Nov 16, 2016 4:24 pm
Yes. 45 is the profile rating expressed as a % measurement of the width.
So a 225 45 tyre has a nominal profile "height" of 101.25mm
A 215 45 is 96.75 mm
Doubled up to calculate diameter, that's 9.5mm difference actually, so more than my original estimate...
Post by campbell » Wed Nov 16, 2016 4:25 pm
I may have answered my own question!
Post by mckeann » Wed Nov 16, 2016 4:30 pm
Post by mckeann » Wed Nov 16, 2016 4:34 pm
according to that, your gps speed at an indicated 70 mph will be 68.9 and will drop the diameter by 1.01 cm so i dont think its anything to worry about.
Rosssco
Post by Rosssco » Wed Nov 16, 2016 4:56 pm
You can get that much of a difference between the same listed size but with different manufacturers, dependant on construction type, so I doubt a potential 5mm difference will make nany noticeable difference.
Plus, the narrower the tyre the better in winter should you encounter heavy snow / ice.
VX220 SC
M135i
Parajet V3 Moster 185
Post by tut » Wed Nov 16, 2016 5:23 pm
I dropped down from 225 to 215 for the Honda CR-V but then never fitted them.
Post by campbell » Wed Nov 16, 2016 8:20 pm
Cool. Just need to persuade The Missus now :-/
Dark
Post by Dark » Wed Nov 16, 2016 11:22 pm
What width are the rims? You need to check that the narrower 215 is compatible.
Most likely they are okay but the tyre will protrude less over the edge of the rim so more risk of curbing the wheel - you can use your voucher! ;)
The car will also be riding ~10mm lower so more risk of scraping the underside of the car on a rogue speed hump, etc.....
Post by campbell » Wed Nov 16, 2016 11:37 pm
It'll be 5mm lower.
The voucher has just been deployed :-)
Good point re rim width. Need to check that...
Post by j2 lot » Thu Nov 17, 2016 12:01 am
Post by campbell » Thu Nov 17, 2016 12:20 am
That's useful. 215 is "ideal". Ok more ammo for the Missus chat !!
Post by Stephen » Thu Nov 17, 2016 8:05 am
I use 205 65 16 during the winter and 235 45 17 in the summer
