Creaky clutch pedal
tuscan_thunder
Creaky clutch pedal
Post by tuscan_thunder » Fri Oct 20, 2006 9:06 am
As title, pedal creaks and feels a wee bit stiff like there's stiction in the action. Feels like it's in the top of the pedal where it disappears into the bulkhead.
Does it engine on, off any speed any temp so I'm pretty sure it's just the top of the linkage.
What's best stuff to use to lubricate it and where do I lube it?
Post by Sanjøy » Fri Oct 20, 2006 9:10 am
Jsut bought some of this stuff which I think Lawrence puto n my clutch pedal last time as it is in the same stateas yours.
http://www.edinburgh-bicycle.co.uk/cata ... m?ID=18945
DaveG
Post by DaveG » Fri Oct 20, 2006 10:04 am
I use a can of spray silicon lube that I picked up from halfords. The fact that it sprays makes it easier to get it onto the pivot.
D
tuscan_thunder
Post by tuscan_thunder » Fri Oct 20, 2006 10:52 am
thanks lads
Post by alicrozier » Fri Oct 20, 2006 11:58 am
John,
I've got a big spray tin of Silicon Lube you can borrow. I'll be at home this afternoon if you want to nip in past the flat on your way home
Give me a call on my moblie.
Ali
Post by tut » Fri Oct 20, 2006 1:09 pm
Does Nicola know that you are giving it away Ali? <BG>
Post by Gareth » Fri Oct 20, 2006 1:17 pm
tut wrote:Does Nicola know that you are giving it away Ali? <BG>
Post by alicrozier » Fri Oct 20, 2006 1:57 pm
Mind in the gutter... :roll: :D
tuscan_thunder
Post by tuscan_thunder » Fri Oct 20, 2006 3:14 pm
alicrozier wrote:John,
Ali
I've got a big tin of it at hame so I'll be sorted, cheers Ali.
Post by Sanjøy » Fri Oct 20, 2006 3:19 pm
Fcku me Shug must be busy with the new job to be passing up on all this.
Post by tut » Fri Oct 20, 2006 3:24 pm
Yep, at one time Shug and IainT would have been in like hairy snakes, before my fingers could have reached the keyboard.
Post by tut » Fri Oct 20, 2006 3:25 pm
Ali 751 posts...........
tut 752 posts...........
Post by alicrozier » Fri Oct 20, 2006 3:34 pm
tut wrote:Ali 751 posts...........
Quality not quantity (apart from this one!)...
Lawrence
Post by Lawrence » Fri Oct 20, 2006 6:26 pm
It's "Dry Slide" I use which is a dry graphite suspended in a liquid for application.
It's particularly good on aluminium to aluminium joints, the liquid dries to leave just the dry graphite.
Iain Thomas got it for me from a gun shop IIRC
and it does the door hinges too :)
Post by alicrozier » Fri Oct 20, 2006 7:22 pm
This stuff... ?
http://www.russack.com
