AD08R
- craigs135s
AD08R
Going to get some AD08Rs for the Europa. Car has TD 1.2s and the front tyre sizes are 205 50 16 but looking to run 205 45 16 will this cause any issues?
Thanks
Craig
Thanks
Craig
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
Re: AD08R
I ordered the frofile down for the 211 by mistake, only problem was it lowered the front of the car by about 10mm. As it only had 75mm of ground clearance,it was a bit of an issue, so adjusted the ride height to suit.
Stu
Stu
S1 S160
Caterham 310R
Caterham 310R
Re: AD08R
Would expect a 10mm lower side wall, therefore a similar drop in ride height. Doubt it will have much effect, other than giving the car a slightly lower front end.craigs135s wrote:Going to get some AD08Rs for the Europa. Car has TD 1.2s and the front tyre sizes are 205 50 16 but looking to run 205 45 16 will this cause any issues?
Thanks
Craig
Re: AD08R
I run these tyres / sizes on my VX220 as do many.
They work very well (respectible in this mornings snow even!), but the Europa can suffer from the same ABS issues as the VX220 when smaller front wheels are used.
Most just disable the ABS or find a Lotus ABS controller to account for the smaller fronts.
VX220 SC
M135i
Parajet V3 Moster 185
M135i
- craigs135s
Re: AD08R
Rossco do you mean smaller front tyres rather than wheels as am sure the standered wheel for the Europa isn't as wide as the 1.2s? I am sure the ABS controller has been changed will need to look through the paper work of the other owners.
Thanks
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
Re: AD08R
Its not the wheel width, the smaller 16" front wheels / tyres (VX220 and Europa use 17" fronts) can upset the standard 2-channel ABS unit due to the large change on % front / rear rolling radius from OEM. Some are fine actually, but the 'best' solution is to use an Elise / Exige 4-channel ABS controller (straight swap) which is calibrated for the different wheel set-up (and just generally better).craigs135s wrote:Thanks for the response everyone.
Thanks
C
Your's might already have this, but I was under the impression most Europa's come with the same ABS unit as the VX220's.. You can tell with the part number on the underside when the controller (black lump on the ABS unit) is removed.
VX220 SC
M135i
M135i
- craigs135s
Re: AD08R
Thanks Rossco. Yeah am sure the ABS controller has been updated but will give it a check.
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
