S1 bonnet
- thesurfbus
Re: S1 bonnet
It is adjusted via the washers/shims under the front hinge which will raise/lower the leading edge.
From memory there is more than one and they are of different thickness, so try taking out or adding on a thin one.
Re: S1 bonnet
What Tut said. Just one word of advice - if you are doing this, make sure the catch aligns nicely as if it doesn't it will get stuck shut and require some brute force to open.
You may also get away with just loosening the three bolts on the hinge and slightly re positioning the bonnet.
Re: S1 bonnet
Also note the rubber stoppers that it sits on at the front as those can be adjusted up and down for the hatch to close against.
Re: S1 bonnet
It's adjusted by wearing away excess material and then repainting. Repeat until you decide it doesn't matter
Re: S1 bonnet
I also replaced the rivets on mine, with nuts n bolts, IIRC.
Re: S1 bonnet
Check the hinge moves freely, mine used to rub. When the hinge gets sticky the bracket flexes and the bonnet folds towards the clam.
Spray it with WD40 and exercise it.
Then adjust with packers if needed.
