Tyre savers
pshanks76
Tyre savers
Post by pshanks76 » Fri Oct 02, 2015 8:51 am
I'm looking at getting some tyre savers / cradles for when I put the Elise away in the garage for winter to stop flat spots and looking on the web there seems to be 2 options;
Expensive - Car specific cradles like the Race Ramps RR-FS: http://www.ebay.co.uk/itm/Race-Ramps-RR ... 4d19e55383
Cheap - caravan/camper cradles like the Fiamma tyre savers: http://www.amazon.co.uk/Fiamma-Wheel-Cr ... B00BTI15DI
Has anybody used either or have any opinions??? The Fiamma's can be joined together to be wide enough for my rear tyres and 3 sets will work out about £44 versus £118 for the Race Ramps.
Elise S2 135r no more... Crossed to the dark side with a Boxster 981s
BMW 330D x-drive m-sport touring
Autosleeper Duetto camper
donaldosaurus
Re: Tyre savers
Post by donaldosaurus » Fri Oct 02, 2015 8:59 am
pshanks76
Re: Tyre savers
Post by pshanks76 » Fri Oct 02, 2015 11:39 am
Yeah, they're even cheaper. I will probably just stick some rubber to the base of them to stop them slipping and a bit of extra cold protection (from the concrete floor) and job should be a good 'un.
Re: Tyre savers
Post by Ferg » Wed Oct 07, 2015 9:51 pm
For the non caravan user... do these work?
pshanks76
Re: Tyre savers
Post by pshanks76 » Thu Oct 08, 2015 12:49 pm
I've heard they do... my folks use them and say they work. They spread the weight across a larger surface area and create a barrier between the cold. I think I'll just get the cheaper ones and see how they go!
Re: Tyre savers
Post by Ferg » Thu Oct 08, 2015 10:25 pm
Let us know how it goes. I was thinking of putting foam floor padding down for the car to sit on. Unless the curve of the tyre savers closely matches the curve of the tyre, I imagine the effect should be similar.
ClarkyBoy
Re: Tyre savers
Post by ClarkyBoy » Fri Oct 09, 2015 10:08 am
A few of the guys in the racing fraternity use those wheels skids, keeps the tyres off the flat and you can move the car around really easily without having to mess about taking them on and off the ramps
Vanlife Sprinter
E30 318is / axle stand spec
987.2 Cayman S
[#]=///=[#] ‘88 Panda 4x4
BSA B31
MF35
Stiga Tornado
Many Bicycles
Re: Tyre savers
Post by Dominic » Fri Oct 09, 2015 10:25 am
Ferg wrote:Let us know how it goes. I was thinking of putting foam floor padding down for the car to sit on. Unless the curve of the tyre savers closely matches the curve of the tyre, I imagine the effect should be similar.
Nice foam flooring is cheap and cheerful - lovely to be on when working on the car, saves the tyres a little - esp if like me you always park in the exact same spot - leaving dents in the foam floor. Aldi do garage flooring from time to time - costs buttons. Seems to be about the same as the play matting you get for kids, but much cheaper! If you go for it, one tip; leave an inch or so around the edge, as through use, it expands - like dough being rolled with a rolling pin. I didn't, and had to go back around it trimming the edges. :thumbsup
thinfourth
Re: Tyre savers
Post by thinfourth » Sat Oct 10, 2015 9:17 am
Or
A jack and some axle stands
pshanks76
Re: Tyre savers
Post by pshanks76 » Sat Oct 10, 2015 11:03 am
I read on a PistonHeads thread that prolonged periods on axle stands isn't great for the shocks... No idea if there is any truth in that though?
I hadn't really considered the foam/rubber matting as a solution but the more I thought about it the better it seems... Means I can easily manoeuvre the car when I need to access my garage loft, so I've ordered some matting which should be here next week. Will post some pics once in place.
Re: Tyre savers
Post by Dominic » Sat Oct 10, 2015 11:48 am
pshanks76 wrote:I read on a PistonHeads thread that prolonged periods on axle stands isn't great for the shocks... No idea if there is any truth in that though?
