Run away odometer
fudnie
Run away odometer
Post by fudnie » Thu Jul 16, 2015 2:43 pm
After nipping out for my lunch today, got back in the Elise (2003 S2 111S) turned the ignition on and I noticed the odometer spinning up. It finally came to rest at about 750,000 miles, this may affect the resale value...
I put the ignition off and back on and it is still reading the same value. I thought maybe resetting the stack but i couldn't remember all the magic words but will try again later.
Anyone seen this before? Any ideas on what could cause this or how to remedy it?
Craig
S2 111S blue with silver stripes - The Good
56 Astra in black - The Bad
Rover 45 in maroon - The Ugly
Re: Run away odometer
Post by BiggestNizzy » Thu Jul 16, 2015 3:36 pm
I have heard of this before, only way is to have it reset. There is a serial port on the board that you can use to access it. ( you have to have a decent idea of how to do it)
Post by mwmackenzie » Thu Jul 16, 2015 4:43 pm
750,000 miles... I'll give you £5k for it! I trust the service records are up to date and all ties in? :lol:
fudnie
Post by fudnie » Thu Jul 16, 2015 5:28 pm
mwmackenzie wrote:750,000 miles... I'll give you £5k for it! I trust the service records are up to date and all ties in? :lol:
well i did have all the stamps...but then... the dog got.. and water ingress ... and you'll just have to trust me :wink:
Post by Dominic » Fri Jul 17, 2015 9:29 am
Still on it's original head gasket? :)
Post by mwmackenzie » Fri Jul 17, 2015 12:22 pm
2003 was a good vintage! :thumbsup
Post by robin » Fri Jul 17, 2015 11:18 pm
You'll need to get it reset - it's not something you can do for yourself (well, not something normal people can do). You might need to ask Lotus to help you out. Cheers, Robin
Post by tut » Sat Jul 18, 2015 8:26 am
Would it have to be set to zero?
As long as he has the mileage on service sheets and MOT's that should suffice as proof. Could the gizmo that you made for me Robin be used to wind the mileage back on?
Post by robin » Sat Jul 18, 2015 9:05 am
Tut,
No, but it could be used to wrap the clock, eventually, assuming it wraps ... there is a risk that when it gets to 999,999 miles that it doesn't roll over to 0 but just sticks at 999,999 forever.
I believe that the odometer can be set to any value using the data link & appropriate software - that's to allow dealers to replace broken instrument panels and set the mileage appropriately.
Post by j2 lot » Sat Jul 18, 2015 9:52 am
Your options to get it re-set just reduced :wink:
http://www.bbc.co.uk/news/uk-england-bi ... m-33573139
Post by Ferg » Sat Jul 18, 2015 9:54 am
That's great if a dealer can set it. Mine has had a replacement clock at some point and it's rather irritating that the numbers are not right.
Post by BiggestNizzy » Sat Jul 18, 2015 12:49 pm
RDH
Post by RDH » Sat Jul 18, 2015 8:38 pm
j2 lot wrote:Your options to get it re-set just reduced :wink:
Slight thread drift, but one of our Indian employees clocked his company car up the way, after being questioned on his mileage claims, he added 25,000 Kms to his Skoda Superb!
I worked out he would have had to drive 10,000km a week in Hyderabad, which is nigh on impossible!
He didn't remain an employee for long!
Caterham Roadsport 190
Tesla Model 3 LR RWD
