Yokohama AD08R - fronts - where to buy them ?
a4drk
Post by a4drk » Wed Apr 22, 2015 9:00 am
S2 - 111S
My friend has bought/got the rears - 225/45/17 AD08R
He can't find anyone that's stocks the fronts
Upgrade size is 195/50/16
Anyone know where I can get a pair ?
David
:roll:
S2 Exige
Re: Yokohama AD08R - fronts - where to buy them ?
Post by tut » Wed Apr 22, 2015 10:06 am
http://www.demon-tweeks.co.uk/performan ... ad08r-tyre
205 only but probably better anyway on 16"
ps:- even better, includes free fitting.
http://www.blackcircles.com/Order/Baske ... y/32498558
steve_weegie
Post by steve_weegie » Wed Apr 22, 2015 11:26 am
Yep AFAIK, the AD08 only comes in a 205R16 size.
BigD
Post by BigD » Wed Apr 22, 2015 12:09 pm
I have the AD07's on the front and AD08's on the rear and there are no issues whatsoever, they work well together. AD07 fronts are pretty cheap too. :thumbsup
Ronnie at wheelsaround is probably your best bet.
a4drk
Post by a4drk » Wed Apr 22, 2015 12:16 pm
According to Yokohamas website
The 195/50/16 is not made in an AD08r
Nearest is a 205/45/16
But will that fit on a rim that's currently got a 175/55/16?
David
S2 Exige
Post by woody » Wed Apr 22, 2015 12:36 pm
a4drk wrote:According to Yokohamas website
David
Not advisable.
There's a website in France that sells the correct AD07 cheaply, I'd imagine especially so just now with the exchange rate. Think it's pneus-online or similar (S1 owner so never took a note).
steve_weegie
Post by steve_weegie » Wed Apr 22, 2015 12:51 pm
woody wrote: Not advisable.
Yoko's size chart lists this tyre will fit on the S2 rims. It's not too big, but is on the limit for the 16x5.5 S2 front. Yoko rate the fitment between 5.5 and 7.5 :thumbsup
EDIT TO ADD: The above is true for the 205/55/R16 tyre as the 205/45/R16 is indeed the wrong size for the std rims :thumbsup
Post by woody » Wed Apr 22, 2015 2:20 pm
I suppose the concern there would be the 55 aspect ratio with the larger width... may cause issues as you've then a wider & larger diameter overall tyre?
Shpould just buy an S1, can't go wrong. Tyre sizes can't anyway. The car will.
steve_weegie
Post by steve_weegie » Wed Apr 22, 2015 3:33 pm
Yep, you do gain a bit of sidewall height for sure. Brooke Kensington list these AD08's for the S2 though, so I'm guessing other folk must be using them....
roadboy
Post by roadboy » Wed Apr 22, 2015 4:11 pm
They're listed for the S2 as they are fine on wider front rims like the Exige wheels or sport pack forged wheels which are 6J.
You can't run a 205/45/16 on a 5.5J wheel though.
I'd stick to AD07s from pnues-online for the front and AD08 on the back. (Or buy new wheels) :D
HTH
Dan
SPS Automotive
Independent Lotus Specialists
istoo
Post by istoo » Sat Apr 25, 2015 1:53 pm
i ended up as above as well, sorry missed this thread...
according to yokohama site they only produce A048s in 195/50/16s. AD07/AD08 variants all start at 205 with the exception of the 175s which as far as i gather from tyre suppliers are only sold to lotus dealers.
http://www.yokohamatire.com/tires/consu ... ance_cars/
S2 111s
Dark
Post by Dark » Tue Apr 28, 2015 7:45 am
Camskill are selling both the AD08 and AD08Rs. £10 difference in price but what's the difference in terms of the actual tyre?
BigD
Post by BigD » Tue Apr 28, 2015 8:23 am
Dark wrote:Camskill are selling both the AD08 and AD08Rs. £10 difference in price but what's the difference in terms of the actual tyre?
Coincidentally I was just pricing those exact tyres on camskill too. I couldn't see the ad08 in the front size though and the ad08r was only in the 215/45/16 which is probably the ideal size to keep the same diameter. Would need a wider front wheel on S2 elises though.
I think the R is just newer technology so obviously better. Not sure I'd notice the difference. Set of 4 are £450 which is very reasonable. :)
Dark
Post by Dark » Tue Apr 28, 2015 8:30 am
I was only looking at rears.......
I'm guessing these are standard Yokohama tyres; there is no special LTS fitment for the AD08Rs like you get with the AD07s or A048s?
BigD
Post by BigD » Tue Apr 28, 2015 9:00 am
Yeh haven't seen LTS on ad08's. I have them on the rear of mine. Ad08r's that is and they are a great tyre. Again I doubt I'd notice any difference between LTS and non. Still 5mm tread left after 3 dry track days and they were very good on cold wet roads too.
