How the **** to you remove the third bolt (hidden from view next to the engine block) that holds the thermostat housing onto the water pump?
I spent hours yesterday trying various methods.
I've removed the exhaust manifold (seems to help a bit)
The water pipe is free of the housing rubber pipe (boy was that on tight)
Its a pig of a job, easily worse that front clam or anything else I've done on the car. There is NO room, everything is zip tied to each other. Its a freaking nightmare.
Think I'm going to have to remove the inlet manifold (and there are some difficult bolts I can see.)
Any tips?
I need to remove the thermostat as I think its faulty and stuck closed.
Thanks
James
