On three...
pete
Vexatious Litigant
On three...
Post by pete » Tue Jul 15, 2014 9:59 pm
'Tis a lovely summer evening and I'm in the garage...
Car's running on three.
Changed the spark plugs and leads. There was a problem on number 2, lead arcing to plug (he guesses).
Drive it again, thought it was fixed. It isn't. Barely running. Got towed.
Changed the coil packs. No change.
Pulled the plugs. Number 2 plug has a white powder on the outside.
But number 1 is bent and has zero gap...
Mr Nizzy came to the rescue with a feeler gauge! Gap restored. And it's still on three, his ODB2 reader says misfire on 1.
So new coil packs, plugs and leads. Why has the gap closed, must have hit the piston I guess?
It's off to the local garage I guess but aby more diagnostic ideas would be great...
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
Re: On three...
Post by woody » Tue Jul 15, 2014 10:48 pm
pete wrote:'Tis a lovely summer evening and I'm in the garage...
The plug has closed again?
I diagnose Apeitus anyway.
Re: On three...
Post by BiggestNizzy » Tue Jul 15, 2014 11:12 pm
Nope
pete
Vexatious Litigant
Re: On three...
Post by pete » Tue Jul 15, 2014 11:16 pm
FFS I nearly googled Ape-itus.
It's not closed again (we checked that).
It has been suggested that the wrong plugs have gone in - it has Bosch Super Plus FR6KPP33X-54 and despite my adeptness with google I can't establish if they are wrong (I suspect so - SELOC says +34 as a Bosch model number...
Hmm.
'11 - '17 S2 135R
'23 - ?? Evora
Re: On three...
Post by tut » Wed Jul 16, 2014 7:53 am
pete wrote:FFS I nearly googled Ape-itus.
I did........still did not get it until the hyphen.
Re: On three...
Post by robin » Wed Jul 16, 2014 8:36 am
Clean up (and gap if they are wildly out) old plugs and put back in.
Compression test.
Any coolant loss?
pete
Vexatious Litigant
Re: On three...
Post by pete » Wed Jul 16, 2014 9:19 am
No coolant loss.
Cleaned up and re-gapped, no change.
I can only think that a piston hitting the plug has caused it to close, although the amazing MMC out of hours tech support suggested wrong plugs so I'll need to check that... ('twas the local garage who changed the plugs as they were, well nearer).
I'll check the plugs this morning and failing that a compression test...
'11 - '17 S2 135R
'23 - ?? Evora
Re: On three...
Post by mckeann » Wed Jul 16, 2014 12:19 pm
ape-itus can be cured by lending me the car for a week.
I'll give it a right good rag, and fix this problem.
*T@C's - car may return with some new problems*
pete
Vexatious Litigant
Re: On three...
Post by pete » Wed Jul 16, 2014 12:45 pm
mckeann wrote:ape-itus can be cured by lending me the car for a week.
Only an idiot would let you drive their car.
In fact you'd have to be an idiot to even drive a car you had ever been anywhere near.
'11 - '17 S2 135R
'23 - ?? Evora
Re: On three...
Post by robin » Wed Jul 16, 2014 1:19 pm
I don't think piston-to-plug contact is possible. If you think about it, the plug is always where the plug is ... if the piston could touch it, it would touch it.
Unless of course your piston has gained a WWI style german flying helmet attachment :-)
Most common cause of zero-gap plugs is the tech fitting them drops it down the bore hole because the rubbery bit in their plug socket is not working. Plug falls out of tool, hits the bottom of the bore and pinches the gap. I tend to use a bit of rubber pipe to lower the plugs into the bore and thread them to avoid this problem, though it's a long time since I removed a spark plug, so probably can no longer find said bit of pipe :-)
flyingscot68
Re: On three...
Post by flyingscot68 » Wed Jul 16, 2014 1:29 pm
Wrong plugs sounds a possibility, but they'd all be closed if they were hitting the piston.
Re: On three...
Post by Corranga » Wed Jul 16, 2014 3:26 pm
robin wrote:Most common cause of zero-gap plugs is the tech fitting them drops it down the bore hole because the rubbery bit in their plug socket is not working.
Completely off topic, but I had the opposite issue last month when I changed plugs. The plug went in fine, no dropping, but the rubbery bit then stayed on the plug rather than in the socket :shock:
Took me 20 minutes with a wire coat hanger to get it back out :(
Re: On three...
Post by robin » Wed Jul 16, 2014 5:03 pm
I didn't want to go overboard on detail, but that's why I use a bit of rubber tube pushed over the spark plug top contact (sort of 3mm internal diameter). You can then just yank that off once the plug is threaded and then use a rubber-free spark plug socket to tighten :-)
Re: On three...
Post by Shug » Wed Jul 16, 2014 5:15 pm
robin wrote:I didn't want to go overboard on detail, but that's why I use a bit of rubber tube pushed over the spark plug top contact (sort of 3mm internal diameter). You can then just yank that off once the plug is threaded and then use a rubber-free spark plug socket to tighten :-)
Also avoids cross-threading. Sure I read about doing that in an old workshop manual for that reason somewhere.
Re: On three...
Post by robin » Wed Jul 16, 2014 6:48 pm
Shug wrote: Also avoids cross-threading. Sure I read about doing that in an old workshop manual for that reason somewhere.
I am old ...
