Attaching rear-view mirror
cla5h
Post by cla5h » Thu Apr 10, 2014 7:44 pm
Hi,
I've tried searching but can't find anything for what must be a common Elise problem - the best way to re-affix the rear-view mirror. Any recommendations? Something strong enough to hold the weight of the mirror obviously, but should I worry about being able to remove it again should the need arise (e.g. if replacing windscreen) or just use the strongest glue I have?
s29ttc
Re: Attaching rear-view mirror
Post by s29ttc » Thu Apr 10, 2014 7:47 pm
I think you get glue specially for that, I remember doing mine a while ago and stuck it up been fine ever since, but didn't worry about the need for removal.
Edit: yeah as I thought http://www.halfords.com/webapp/wcs/stor ... &langId=-1
1999 S1 Elise 111S - Fun Spec
AJT
Post by AJT » Thu Apr 10, 2014 9:40 pm
Alan
S2 111S
Post by Ferg » Thu Apr 10, 2014 10:34 pm
You can ask at the local windscreen repair place. They use super strong sticky pads. Designed for the job no less. :-D
Post by Shug » Fri Apr 11, 2014 9:40 am
Yep - DO NOT use superglue, as it'll crack the glass, and also note that the mirror is not central on the Elise - pretty far off to the pax side.
cla5h
Post by cla5h » Fri Apr 11, 2014 8:34 pm
Thanks guys - I'll get some of the special mirror glue rather than using the pound shop super glue I have lying around.
ninja
Post by ninja » Tue Apr 15, 2014 4:07 pm
do you legally NEED the mirror?
i ripped the one on my exist S off and was planning a similar fate for the evora mirror
ninja
Post by Ferg » Tue Apr 15, 2014 6:25 pm
No, as long as you have both wing mirrors. Personally I would have one if I possibly could. :-)
cla5h
Post by cla5h » Wed Apr 16, 2014 6:43 pm
As above, I don't believe it's a legal requirement (both wing mirros will suffice.) However, I've missed not having it - I like being able to see who's coming up either side of me. Got the Halfords kit and just reattached it tonight, so hopefully that sticks.
hardrockjock
Post by hardrockjock » Thu Apr 17, 2014 11:19 am
Mine "fell off" a couple of years ago and I now enjoy the full panorama with no anoying blind spot in the middle. It was not an issue for the subsequent MOT'S either.
Post by BiggestNizzy » Thu Apr 17, 2014 12:38 pm
