Winter Tyres - Pressures
jimbo
Post by jimbo » Fri Nov 29, 2013 10:34 am
Hi all,
Don't have my manual with me, could someone tell me the tyre pressures for running winter tyres please on my S1?
Thanks
James
S1 Elise 111s
scottishselise
Re: Winter Tyres - Pressures
Post by scottishselise » Fri Nov 29, 2013 11:27 am
Sorry I don't have the figure but my understanding is that it is usually 10-20% lower than standard pressure depending on personal preference.
Last year I had nankangs on my car that were rather wobbly even in cold so I put them to close to normal Tyre working pressure.
Stevoraith
Post by Stevoraith » Fri Nov 29, 2013 2:41 pm
scottishselise wrote:Sorry I don't have the figure but my understanding is that it is usually 10-20% lower than standard pressure depending on personal preference.
You normally set winter tyres to a HIGHER pressure than summers.
Not sure if this is because they need a higher pressure to work or because normal recommended pressures are for a higher ambient temperature than the average ambient in winter so you are just correcting for that but anyway, I think they should be something like 2psi higher for winter tyres than the recommended summer pressures.
VX220 2.2 - Gone
Post by Mikie711 » Fri Nov 29, 2013 2:52 pm
Just had a look at the manual for the S1 and for winter tires it says that the rears are supposed to be mounted on a standard front wheel. I have a later version of the same manual that then says that the normal 16" is used, weird.
Anyway, Front 185/55 R15 1.8bar (26psi) and rear 205/55 R16 1.9bar (27.5psi). These are narrower than standard but even if you are running normal width 195/225 front an rear should be a good starting point.
jimbo
Post by jimbo » Fri Nov 29, 2013 3:30 pm
Thanks Mike, just had the AA pump the front left up to 30psi on the basis that it's leaking, and from there I can keep topping them up until I get them sorted properly. Have now booked them into the wheel specialist for next week to have them refurbished and powdercoated satin black
CRAP timing for costs, but what can you do :(
S1 Elise 111s
scottishselise
Post by scottishselise » Fri Nov 29, 2013 6:45 pm
:oops:
Perhaps nitrogen filled will help to reduce fluctuations cold weather causes.
